Wesley Bush, the TE error code indicates that you have a problem with the touch keypad communication between the control panel and the main control circuit board. You could try and see if you have a "gunked" up touch panel, if the ribbon cables are still okay and properly seated. To remove the keypad / control board from the microwave, there are three screws on the bottom at the front to remove. Once those are removed, the keypad is held on by clips. Slide the entire keypad to the left and it should come loose. After it is loose, carefully remove all the wired connectors to the microwave. Please remember that working on microwaves can be extremely dangerous and I'd suggest to either have it repaired by a professional or to replace the microwave. Hope this helps, good luck.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
