Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
Does this mean my battery is going?
I bought an iPod 3rd generation on ebay. The owner said they had replaced the battery at some point, but did not say when. Basically when i charge it, it does not register a charge at all at first. Then as I listen to it, the battery bar gradually goes up. The battery drains kinda fast too.
crwdns2889612:0crwdne2889612:0 -1
I would say yes - there is a problem with the battery - but don't forget - the battery rated life is way shorter than in newer models
on the iPod wiki page is a list where you can compare them - the times are for new batteries - so a used one can be slightly off . your model should work around 8h with a new battery (that means continuous play - not every 2 seconds switching the song ;-) )
as i mentioned in one of your other questions - i would sell it and get a different one from ebay - if you need looooooong playtimes - a nano 3g works great - have one that playes 25.5h in shuffle mode, my mini plays around 5.5h - but thats ok - the plus side of the mini is the compatibility - if the 4gb microdrive dies - i can put a cheap compact flash card in it, my nano 1g works for 6.5h (times always in shuffle mode)
Sarah crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,292
