A pocket-sized GPS navigation unit, popular among motorcycle riders for its small size and long battery life.
change the battery in Garmin Quest?
I have a Quest since it came out - and LOVE it. Has anyone successfully replaced the internal battery?
Mine is ok at the moment, but I dread the thought it may die and ..what then? Still does 12 hours of GPSing - great on the Motorbike, no wires needed
All the new ones only do 5 hrs when new :(
crwdns2944067:04crwdne2944067:0
Avez vous un site permettant de dialoguer en français ?
== Update ==
Je souhaiterais pouvoir dialoguer en français
== Update ==
Que demander en plus ?
== Update ==
Je voudrais changer la batterie d'un GPS nuvi 760
== Update ==
batterie pour gps garmin nuvi 760
What forum would the Garmin model 12 be in?
.I have Garmin nuvi2598Lmthd. The display shows that low battery.how can I fix it.I had two Garmin GPS it had the same problem I changed the battery It did not work.please give me solution.
I changed the battery in mine still not charging? Worked for about 2 hours after I changed the battery, but now it’s not charging?
This is the only thing I found on it, looks like it's possible but you can't get a battery specifically for it.
http://www.fixya.com/support/t550175-rep...
cheers!
Battery available from Battery.net approx $15.00. Unscrew metal threads and split case. Unplug battery remove and reglue the replacement battary back in as it was fitted by Garmin. Great unit and mine is on of the first as well. Now leave and use it on my Burgman 650 Maxi Schooter. Just purchased a Garmin 2460LT ($320 Aus) and I think this is better than the Quest was in it's day but not as clear in daylight conditions as the Quest. To easy. Regards Ross
Yes I have had me a long time to0. I just bought a Garmin 2460LT and it is top shelt stuff.
To replace battery unscrew unit and prize out batt from the potted bed of clear silacone and un plug from circuit board. The carfully clean out residual silacone and replace battery in GPS housing in the same position with the same amount of dobs of silacon and screw the two half back together again with great care. Battery available from
11team crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 4,742
