7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
crwdns2934591:0220crwdne2934591:0 crwdns2934593:0crwdne2934593:0
LCD flickering after digitizer replacement. Tried new LCD, still same.
The LCD had no issues when the customer brought in the ipad mini. When I replaced the digitizer, the lcd was all greyed out and 2 black lines running down the middle. I assumed it was a bad LCD so I tried a new one and the same problem persists. Could this be a board issue? If so, is there a fix?
Tried hard reset, same issue.
Original LCD http://imgur.com/tonBntl
New LCD http://imgur.com/NZk3zeS (red is to protect customors identity, not on actual lcd)
crwdns2889612:0crwdne2889612:0 -1
This is probably a logic board issue. What most likely happened is that a connector was damaged. You may need to replace it.
crwdns2942205:01crwdne2942205:0:
Thanks, that's what we thought. We'll try apple and see what they have to say.
Were you able to fix your problem? I am confronting the same issue. The screen is flickering(the image jump and jump all over the screen) Both LCD I have tested so far are broken inside, so I don't know if this flickering is caused by the broken LCD or by the connector.
Let me know, thanks!
Robert crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 1,045
