E82 error code on 360 S
I have a E82 error code displayed and a Red LED light at the 360 S console. What should I do to fix it ? Tks
Ben Ho, "E82 has been a common error on the slims for some time since release, E82 error is the GPU has overheated and come unseated from the main board. Try to turn the console on without a HDD in place. The HDMI cable also may be a reason so try to use a standard AV-cable. If the console still displays the error, then you may have to reflow/reball the GPU. Also, check with MicroSoft and see if it is still covered under warranty. Hope this helps, good luck.
why is the xbox360 have red rinhg of death
@andrecious32 are you asking this as a general question? You just want to know why the Xbox360 was plagued by the RROD?
@David Garcia not sure about HHD but if you are ferring to HDD that stands for Hard Disk Drive. Here are the guides to work on your Xbox Xbox 360 S
That might be it. The problem I’m having is everytime I plug in an AV cable or a HDMI cable, the power button in front turns red@oldturkey03
How did you fix it?
crwdns2947631:0crwdne2947631:0
crwdns2947633:0crwdne2947633:0crwdns2936751:024crwdne2936751:0 3
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 55,376
E82 solved - reheat cpu 350 degrees C / 5 minutes.
Working very well now.
crwdns2934271:0crwdnd2934271:0 narcis crwdne2934271:0
my xbox 360 S keeps on showing red lights
can I have some help
crwdns2934271:0crwdnd2934271:0 Hamza Saeed crwdne2934271:0
it says E82 and I have tried to fix it but it still says it
what should I do?
