The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
My car is losing power and killing my battery?
I need fuse box diagram to troubleshoot my connections so, I could see the fuse inputs in my 93 Honda Accord SE. I got a fuse box diagram for 93 Honda Accord but it is different from mine. Please help I'd appreciate it. Thank you
Is this closer to the fusebox in your car? http://i6.photobucket.com/albums/y205/pr...
Its your alternator is bad
Two places to start. First get a volt meter and measure voltage of battery, then start car and measure again.
Running voltage should be 13+, battery itself 12.8 or more. A car this age will likely start on a dying battery (under 12.2ish) but should stay running if alternator is charging.
Second- go to any auto parts store and they will run a quick check for free. This should answer most any other questions.
It is possible that you have a bad relay but unlikely. These can often be tested by swapping a light (pop up headlights?) or AC relay to the charging slot.
jsandoval7988 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 241
