The Motorola Atrix 4G is dual-core Android-powered phone by Motorola. Model Number: MB860.
No backlight due to water
cleaned th phone with wet cloths and then cleaned with isopropyl (Rubbing alcohol ) which goes inside and visible through the screen . alchohol is bad conductor of electricity . i put the battery inside and charged also . worked for 30 minutes but after removing charger it was working suddenly .it start blinking and back light went off. The icon s are visible(DIM ) at some angle with external light . Phone is working , touch screen is working .So what i have to replace or it will be OK just by cleaning .
sandy, rice is only good as a first aid. It will not remove all the water and moisture, nor will it prevent corrosion. I suggest you clean your phone once more. Disassemble every part off it and soak it in 90%+ isopropyl alcohol. Clean all the parts with a soft brush, including the logicboard and all cable connectors. Check for burned, missing components. You definitely want to replace the battery. After that, reassemble and re-evaluate. If you still do not have a backlight,replace the display assembly. I can not stress the cleaning enough. If you o not do that, your phone will eventually fail due to corrosion damage. The same goes for the battery. Once a battery has been exposed, you do need to replace it. Hope this helps, good luck.
please use small plastic with RICE and put the phone by 24 hours. The rice will be absorb the humidity. However this is a 98% from can be work. If after you did the problem remain , the backlight is faulty.
God bless you
sandy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 561
