Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
crwdns2934055:0crwdne2934055:0
Restore Loop after logic board replaced
I replaced my logic board tonight and when I put it all back together and I booted it up, it said connect to itunes, I had to restore the phone and it keeps asking to restore the phone because it was detected in recovery mode, I triple checked every connection and i have no earthly idea whats wrong with it..
crwdns2933315:06crwdne2933315:0
Hey gregdudds and wolfi, I used the latest redsn0w and I used the recovery fix option and I got it out, but what I had to do was do the recovery fix, and then it went into recovery mode, and I unplugged and let the screen go blank, then I plugged my phone into the computer for about 2 seconds and unplugged it and it booted, but the home button and lock button still don't work, but I use the assistive touch and I keep the auto lock feature on none, but it kills my battery because the screen is always on.
Op here, UPDATE
It booted and works fine, but the home and lock button are not working now, the volume/vibrate works so it's not the flex cables, and the mic, speakers and lightning port work fine, so its not any broken/torn cables.
try this, it should take it out off the loop
http://blog.firmwareumbrella.com/
hi chris, same problem here!
after replacing the power-mute-volume cable the iphone 5 went into recovery loop!
what did you do to get i out?
plz help!
After replacement of an audio button/power button, i've had the same problem.
redsn0w with unplugging after 2 seconds from reboot worked for me, but Home and Power were not responding. I still can't fix it, but have found the root of a problem:
disconnection of the battery cable from logic board without turning the device off.
For Me, This Issue Indicated A Problem With The Power/Volume Flex Cable. Nothing Looked Physically Wrong With It, But Upon Replacing It, Everything Booted Up And Resolved Perfectly. Upon Trying Other Solutions To Exit Recovery Mode, I Just Kept Getting A Loop. However, Upon Replacing This Flex Cable, It Works!
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,340
