Can backlight of MB Air display be powered on w/o motherboard?
Hi to all electronic wizards,
my 11" 2011 Macbook Air display seemed cracked and had sort of a color bleeding growing from the crack, making it unusable. I swapped it with a new display using a great iFixit guide, so the computer is good as new.
The old display still has nice, even, white light (except from where the crack is, of course), and I thought it could be reused as a small slide sorter, as I have a project coming up where I will be sorting a couple of thousand slides, scanning the best ones.
Does anyone know if it is possible to light the LED backlight of the display without it being connected to a motherboard, for example just by supplying current to the right wires? I have little knowledge of electronics, but have soldered before and I think there is very little to loose here, anyway.
I was hoping someone could suggest a solution, or eventually tell me if this is totally hopeless.
All the best!
- Ivar
I can't align the text with the images, but they show:
- Overview
- LVDS cable, motherboard end (2 pics)
- LVDS cable and connector on circuit board in the screen
- Flat cable from LED strip
- Connector for LED strip cable
Hi again, I have found the part number for the LED strip in my screen. It is QT001A-S265-0G. I can't find a pinout. On the back of the inverter board (or the screen controller or whatever, I guess it's not an inverter board really) it says DCN202602L3DN57A5 LGD LP116WH4 TJA3 116B151401TAW 411A. Googling for LP116WH4 TJA3 tells me that I have an LG panel with this name, without backlight, meaning that the LED backlight is a separate part from the LCD. This link: http://www.panelook.com/LP116WH4-TJA3_LG... tells me that the signal interface to this LCD is eDP (1 lane), this is short for embedded display port, so it should be following a standard. I'm still hoping someone can help me sort this out, so I can power the LED backlight either through the LVDS cable, or directly to the flat connector on the LED strip.
All the best, Ivar
crwdns2934271:0crwdnd2934271:0 Ivar O crwdne2934271:0
Ivar O, any chance for some Hires images of the board that is connected to your Display? Specially around the connector area.....
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
just an FYI:" the lack of standardization in the industry of LED backlight configuration and LED connectivity. Inside the backlight, there are some similarities in the way panel manufacturers configure the LEDs. This configuration tends to be in multiple banks of series-connected LEDs, but that is where the similarities end. Some manufacturers choose a common anode connection, some choose a common cathode configuration, and others choose a separate cathode and anode connection for each bank. This lack of standardization makes it difficult for designers to address the connectivity of LED drivers. The solution provided by some manufacturers is to add flexibility to support any and all of these configurations. from here
