Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to change connector for cable three?
Hi guys,
I recently bought a used 3gs with a damaged screen, however i found that the previous seller had also damaged connector for cable 3. I have had a look and a new connector will probably need to be soldered on. But I can seem to pin point where the solder was initially applied to the part. is it on the front side of the logic board or the reverse side? Thanks in advance
it's an smd part - that means it's mounted on the surface
on the top left you will find that part - the white one ;-)
but since you asked that way - are there no sings of solder on the logic board ? . that would be bad - very bad
Hi,
Thanks for your help. I am pretty sure its that connector.
Riz crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,656
