have trouble battery charge and no backlit after a replacement lcd
Hi
Post ref chris say
image added! there is a part similar to the fuses described in other posts, a brown or orange smc with an N on it. It reads 8.3v on both sides though.
have you the number of the part for this fuse
I need this because he is wrong in my macbook air emc2392
i have a trouble battery charge and no backlit after a replacement lcd
the fuse backlit is ok and the led driver no dammage
thank you
jean
Update
I join a picture for the fuse N Broken left
jean
http://img842.imageshack.us/img842/1686/...here
jean, not quite sure what part you are referring to. It might help if you give us the number for your logic board i.e. 820-XXXX and post an image of the part that you are inquiring about
The number is 820-2838 A and ssd 504LL/A
thank oldturkey03
jean
jean, I can not access your image right now, so it'll be a few hours...;-)
jean, I hope I have this right :-) if not mark on you image the component in question. The part with the "N" on it is reference designator F9800 and it is a 2AMP-32V fuse in a 0603 package. the only thing this fuse does is to protect the backlight circuitry, not your charging. Hope this helps, good luck.
jean crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 251
