Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Trackpad click button is jammed
The click button on my trackpad has become jammed. It still functions but must be pressed hard to generate a click. Pressure on the palm rests will generate a mouse click because of this condition.
Is this likely to be something that removing the keyboard and cleaning might fix or would I need to replace the entire top cover, trackpad and keyboard?
Thanks,
crwdns2889612:0crwdne2889612:0 26
crwdns2944067:06crwdne2944067:0
it worked omg
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
I fixed it myself without you're help 'cause you said to push on it really hard and i tried that but it didn't work so i turned off my computer by holding the off button and then turned it on holding that button it turned on and i fixed my clicker on my touch pad so I kinda fixed it without your help or any one else's because i'm smart and you're not. Also anyone whom comes on to here go here https://strangefactsandwierdtruths.wordp...
I've this problem too, my trackpad stuck dragging and moving over the screen sometime it selecting by itself and i tried to remove the battery out then hold power botton for 5 second without battery then insert battery back then reboot the device
and after device completed startup , firstly is normal operating system and when i use many apps or open programs in the same time i will have that problem back again
It worked! XD
Bạn cần kiểm tra lại pin xem có bị phồng hay không. Một số trường hợp pin phồng lên gây ra hiện tượng đẩy chuột lên cao và rất khó bấm
crwdns2933315:016crwdne2933315:0
Try to insert a sheet of thick paper around the button to remove dust, dirt or a grain of sand that can be stuck there.
You can't access the button from under the top case so if the paper manipulation don't work you'll have to replace the upper case assembly.
crwdns2889612:0crwdne2889612:0 43
crwdns2944067:028crwdne2944067:0:
Thank you for the quick response.
I have tried the paper technique to no avail. It appears that the underlying button is jammed.
Is there anyway to lubricate the button from the top side?
Good call. I used the corner of a magazine cover and it worked perfectly!
This &&^&^$^ worked!!!!
Blowing on it didn't work well for me... Instead I ripped up an envelope with the sticky strip on it into bits and licked them before gliding it along the track edge to collect any debris inside
Same problem - as a last resort used WD40 while holding the computer so that excess would not run into the main part of the computer. Been working for several years just fine.
crwdns2934275:023crwdne2934275:0
Ok, this may seem a little weird. My trackpad had the exact same issue and I solved it by blowing in it rather hard. Press your lips on the side that is not "clicking" correctly and blow a few times. Make sure your lips build a good seal though.
Or, a short burst of air from a can of can'ed air.
May really just be dust/crumbs stuck under there. This should do the trick though.
crwdns2889612:0crwdne2889612:0 25
crwdns2944067:034crwdne2944067:0:
I was experiencing a different trackpad issue - it was clicking and holding with light taps - and while a reboot didn't work, blowing did! Apparently all kinds of symptoms can show when you have dust, but the solution is simple.
Never comment on these type of things but holy &&8^ it actually worked to blow on it. Was this close to taking my cover off.
the blowing worked for me but when i set my laptop down the lower left corner does not click very well and when i lift it up it clicks fine. Any solutions?
.......blowing actually worked. wow.
Okay, thats crazy and it totally worked!!
crwdns2934275:029crwdne2934275:0
Usually caused by swollen battery pressing on the underside of the trackpad.
You can remove and try and bend the battery outwards for a temporary fix, but
new battery is the only permanent fix.
crwdns2889612:0crwdne2889612:0 9
crwdns2944067:07crwdne2944067:0:
Bending a swollen battery is a very highly questionable solution.
Which is why bending is only temporary fix. I've heard other solutions of taking the battery apart and putting holes in the cells to allow gasses to escape!!!! A slight bend to relieve pressure until a new battery is installed is much more favourable wouldn't you agree? It worked for me and kept me up an running for the week it took for new battery to arrive from ebay.
This could also be due to a defective battery. Remove the battery and inspect to see if it is bulging in the middle. If so, leave the battery out, reconnect power supply and reboot the laptop. If trackpad button functions correctly now it's time to get a new battery!
Swollen battery was totally it for me; thanks sogsy!
Swopped out my battery ( Not OEM Apple battery) and hey presto, problem gone!! Many thanks for the right suggestion.
crwdns2934275:02crwdne2934275:0
I cant believe PRAM reset worked …
Mine stopped working on a very new laptop. I am confident no crumbs or dust was a factor. Turned upside down tapped around no joy. Blowing did not work, paper did not do anything. After few days, decided to give a try to PRAM reset and that worked :) Makes no sense to me but started working right after the reset, give it a try before putting WD40 on it.
PRAM reset plug in power and shut off. HOLD Command + Option + P + R, while holding press power few times and you’ll hear a chime.
crwdns2889612:0crwdne2889612:0 7
Paper didn’t work, blowing didn’t work, I was getting desperate and about to try WD40. So glad I read this first! PRAM reset totally worked! Why is a mystery. Thanks Dan!
Unbelievable! Why would rebooting fix something mechanical??? It worked for me on my wife's 2018 11inch macbook!!!
Indeed unbelievable! It worked! Thank you!
Just worked! I have macbook pro 2018 and it just worked!
omg it worked!!!!!thanks so much!!! i was gonna go to the apple store if anything i dont even think they are open during the lock down.. thanks so much again!!!1
Having dealt with A1181 button issues for many years now, I've found the situation often cannot be resolved, but the first and most effective step to take is to remove the battery (and make sure the battery isn't swollen -- that will cause a problem in itself) and firmly press up on either side of the button from inside the battery cavity. This will usually cause a cracking sound, as a seal formed by years of gunk buildup is broken. This alone will often restore the "click" to a "soft" button.
If that doesn't help, take a look at the underside of the button -- you'll see there is a strip of metal down the center of the button. Take a pair of tweezers and slip the flat end into the small space between the left side of the button and the metal strip, and then pry slightly, making the small space first about 1mm, and then if that doesn't do it try 2mm. This reduces resistance between the left side of the button and the "clicker mechanism" and often restores usability.
But if that doesn't help, it's most likely a lost cause. These topcases are flimsy, and the more you mess with them , the less the chance they are ever going to work again.
Also, as one final thing to try, put the battery back in and see if the push of the battery against the underside of the button helps -- sometimes it does. OEM batteries are best for this since they tend to be thicker.
I thought I would be the odd one out and have to say the blowing didn't work. Instead, I get to say that the blowing was the first step. Then some (unintentional) gentle pressure unlocked it with a click sound as I resorted to having to use the right bottom pad only. Voila! All better now!
Finding this response, after my wife's MacBook core duo did the same thing, and discovering the remedy recommended was to replace the whole top cover, I tried the lub fix.
I took out the battery and hard drive and got a can of WD40 with a straw nozzle. Holding the computer upside down, front lowered and slanted away from the hard drive compartment, flushed the click from the back side with several busts under both sides of the click. I wiped it down with paper towel, cut 1/4" strips of paper and ran them back and forth under the click cover - again on the back side- until they came out dry. Wife says works fine.
What do you have to loose?
Elkhorn 10/4/12
PS Site managers; Would be helpful to have a component list with directive to whether replaceable and in which procedure one should look for instructions. Wondered around a couple of hours and did not find out what to do about replacement until finally I found this hint when I went to send in a question. You helped me with screen replacement on this one and Keep up good work.
This issue just popped up again for me on another MacBook Pro.
Always check the battery first... swollen battery. Replaced it and the trackpad is back to normal.
My trackpad has been stuck before I think it got stiff because of the cold, I blew on it and it worked. Now it’s jammed again at the bottom in the middle. It doesn’t make a “click” noise. I can move the mouse around but can’t “click” on anything unless I hit the right spot with a lot of pressure… tried the paper and it didn’t work pretty sure I got a little piece stuck In there now.. I don’t know what else to do. I don’t want to take my computer apart, afraid I won’t be able to put it back together lol
blowing or papper didnt work for me
what did work was getting a vacuum cleaner and sucking the trackpad back up and/or pressing the vacuum against the trackpad and sucking up around the edges
My macbook air 11inch has a jammed trackpad and I used the method where i slide a piece of paper around the trackpad but it doesn't work. I also tried the blowing method but it didn't work any other solutions.
Blowing worked for me too !!
A small piece of paper, sliding back and forth under the track pad usually does the trick . This has worked for me several times- plus using compressed air is the “ Final Topping “ . Good Luck !
Yes that works great
If a thin piece of paper , using the corner doesn't work , then keep spraying with compressed air. If not the track pad should be replaced. Good Luck : ) !
After years of mainly clicking on the front of the trackpad I realized I could hardly move the back part at all. Just massaged it out with clicks working my way towards the back. The whole things working better now.
This didn't work at all I tried for ages. seems nothing stuck under it? I'm also very clean and make sure I don't get food and dust near my laptop, oh and it's only 3 weeks old.
This is a much newer system as its only 3 weeks old? This thread is for a 2006 MacBook Core Duo.
If this is a new system you have a warranty which you should take advantage of. Find your way to an Apple Store or authorized reseller (where you bought it) to let them fix it for free!
If using the corner of a thin piece of A4 copy paper doesn’t work , then keep spraying with compressed air. If not then the track pad should be replaced . Good Luck : ) !
Steve Mattson crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 155
crwdns2959996:0crwdne2959996:0 344,607
