Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
"no sim" on phone. How do I fix?
How do I most easily repair?
crwdns2889612:0crwdne2889612:0 -1
This may be too obvious an answer for you but here goes:
The SIM (subscriber identification module) is a small chip/card that identifies you uniquely on the network. It is accessible on the top edge of the phone between the on off button and the headphone jack.
There is a tiny hole just big enough for a paperclip to enter and you remove the SIM card by pushing gently in with a paperclip and a plastic frame containing the SIM card will pop out.
check that:
a) there is a SIM card
b) it is seated properly in the device- ie it is seated in the frame properly.
If reseating the SIM doesn't work then I would suggest fining someone you can borrow a working SIM from or go to a store and do that--this way you will know if it is the SIM or the phone.
If none of this helps, then the problem goes deeper and I'm afraid I don't have further suggestions at this point.
Mark Harvey crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,150
