power failure then say F3
will not start unplug microwave then plug back in no functions work. then PF comes up then in twenty seconds F-3 comes up then beeps then goes off
Update
hello its a under cabinet mount quick touch model #363.62709200 hope you can tell the problem and maybe have reair manual for it or where to get parts for it im here in the phillipines they dont see this type or size to much here. thanks
crwdns2889612:0crwdne2889612:0 -1
rick reynolds, #363.xxxxxxxx indicates that this microwave is build by either GE or LG. The F3 error code is an indication of a stuck key panel. Unless you are used to working with microwaves, I do not recommend to work on it. Even when unplugged, there are some components that hold a charge of +25.000 volts. So unless you know what you are doing, I recommend getting it properly service or replace it with a new one. Hope this helps, good luck.
rick reynolds crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 4,200
