Try removing the battery and powering up with just the AC adapter
From the 5310 service manual which I believe is similar to the 5315 and has been uploaded and linked on the 5315 device page
Power System Check
To verify the symptom of the problem, power on the computer using each of the following power sources:
1. Remove the battery pack.
2. Connect the power adapter and check that power is supplied.
3. Disconnect the power adapter and install the charged battery pack; then check that power is supplied by the battery pack.
Attached are a couple of excerpts from the manual that may be useful. As they are from the 5310 manual the voltages may not be accurate.
May also be worth checking the connections onto the main board - I have highlighted in YELLOW the battery connector
BTW If I am incorrect about the similarities between the 5315 and 5310 please let me know and I'll correct the information accordingly.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
12
crwdns2944067:010crwdne2944067:0
DUDE!!!! Thank you!!! It worked!!!
crwdns2934271:0crwdnd2934271:0 andystovall26 crwdne2934271:0
I havr aspire4736z but still ithave no sign of power,cmos battery is 3v any solution?
crwdns2934271:0crwdnd2934271:0 Akbar crwdne2934271:0
Hello I have an acer aspire v5-431-2471 I need a new battery but I still use the laptop while it is plugged in and now it won't turn on I'm not seeing any sign of power on it please help me. I have projects due
crwdns2934271:0crwdnd2934271:0 Leah Garcia crwdne2934271:0
Hello i have an acer aspire E 15 start i need your kid for my problem my laptop are dead and i want to fix but i cant. Please help me
crwdns2934271:0crwdnd2934271:0 Kiribati crwdne2934271:0
Moshi moshi. I have this acer aspire e1-531 laptop and the indication light for charging is not glowing. Even when the charger is plug in, it will not charge. No power, led not turning on. Any ideas how to troubleshoot?
crwdns2934271:0crwdnd2934271:0 kibi crwdne2934271:0
crwdns2934275:05crwdne2934275:0
