The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
How do I fix a green screen on my Razr?
I dropped my phone about 6 months ago and the screen turned blue. After a few shakes it went back to normal.From then until now, when I turn it on it is green until I shake or tap it on something. It is taking longer and longer to go back to normal. Does anyone know what the problem might be or how to fix it?
I dropped my phone on wet ground with the cover on. It seemed fine and not wet. Later the volume controls started muting and then the screen had a green tint. Rebooting in safe mode did nothing and turning it off for 12 hrs did not help either. It is a moto z4. I also have a white very thin line on left of screen border now. What is causing this and can it be fixed. My phone is sealed so I cannot just take the back off and check any wires or connections.
Cynthia Miller, this could be a loose connection on the LCD as well as the connector. I would suggest to disassemble the phone and to take a look at the connectors, cables, and components of the logic board. If they look okay, replace the display. this video should help in getting into your phone.
thanks i will try it and see if it works
Cynthia Miller crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 8,897
