The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
The mobile does not charge unless it is completely shutdown
when i use the mobile it doesnot charge at all so i shutdown the mobile to charge it and wasit for 6 hours to get full battery
lylas, you did not tell us exactly which Tab 2 you have. do you use the original charger? How do you charge it?
lylad, it is possible that your battery is discharged to low. "
When your battery is low, the device will emit a warning tone and show a low battery message.Recharge your battery to continue using your device. If the battery is completely discharged, you cannot turn on the device, even while it is charging. Allow a depleted battery to charge for a few minutes before you try to turn on the device. You do want to check your charger and make sure that it is functioning first. also remember that this device is one that does not (or if it does, then it is very very slow) to charge from your computer. you will need to use the Samsung charger. Hope this helps, good luck.
there is an option in your settings that if checked the tablet will not charge unless it is off. the fix is to uncheck it. hope this is your problem and it helps you out. :)
Where is this option in settings. I've looked in all the settings areas and can't find this option
lylas crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,365
