brew head gasket replacement instructions
I removed the old gasket and can't figure how to install the new one, need some help on how to install it in place
You must first remove the brew screen in order to replace the gasket, as it helps hold it in place. Remove the phillips head screw in the middle of the screen, then the screen itself. Make sure the inside surfaces of the brew head are clean of coffee or pieces of the old gasket, as these can prevent the new gasket from sitting flush. You may need to use a flat-head screwdriver to pry the gasket into place, but once you have it most of the way in you can attach your portafilter to help press it the rest of the way home. Then simply replace the brew screen and screw, and you're done.
how do you remove the old gasket?
Just dig it out with something sharp. If it's really old and brittle it will probably break into pieces, otherwise try to spear it with a small screwdriver, that will make pulling it out a little easier.
crwdns2942667:0crwdne2942667:0 2,107
crwdns2942205:01crwdne2942205:0
Hi
Where can I buy a new gasket?
D
crwdns2934271:0crwdnd2934271:0 Mr Bean crwdne2934271:0
