How do I unlock my apple iPod touch?
I have a apple ipod touch and my cuzins locked it until it said connect to itunes and i need to know how to get there to unlock it, please help it is an emergency. Thanks!
sincerly,
me
crwdns2889612:0crwdne2889612:0 18
crwdns2944067:05crwdne2944067:0
I need to know too, because my brother locked mine up so can you tell me ASAP from a person P.S can u please do that for me I thank u
I am having the same trouble
press and hold the power and home button and see if that works &&^&^$^ &&^&@* ##&&%#@
##&&% ##&&% what does it spell b I t c h
&&^&@* mother &&^&@* what does is spell mother F U C K E R
tytianahall, check what Apple has to say about that on here http://support.apple.com/kb/HT1808
A restore on the other hand will return the phone to its default settings and YOU WILL lose all information. You should only do that as a last resort and only do it on the computer that you normally sync with. That way it should restore the last backup. Check on here for directions on how to do that.
The only other thing would be to put your iPhone in DFU and restore, again YOU WILL LOSE all data since the last backup.
DFU Mode
Connect your iPod to your computer
Turn your iPod Off
Press and hold the power button for 3 Seconds
While continuing to hold the Power button, press the home button as well for 10 seconds
While holding down the home button, release the power button for another 10 seconds
iTunes should now detect the iPod in recovery mode, press OK, and restore your iPod. you may now release the buttons. If you have not reached this point, then you have not entered DFU Mode DFU Mode Hope this helps, good luck.
i forgot the apple id ok how open my iPod 5
Press the sleep button and the wake button on the top of ur IPOD AND PRESS THE HOME BUTTON @ the same time. hold button for 10 seconds.BE SURE TO PLUG IT UP TO I TUNES.
found an ipod touch in a room I wuz cleenin & nobody wood klaim it. how do I unlock it?
tytianahall crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 10,332
