How can I replace my pcv valve?
how can i replace the PCV valve?
You need to go to your library and check out the Haynes manual for your vehicle for replacement instructions. I am including a link showing the location of the PCV valve. Good luck.
John Valdez, " DIAGNOSIS AND TESTING - PCV SYSTEM WARNING: APPLY PARKING BRAKE AND/OR BLOCK WHEELS BEFORE PERFORMING ANY TEST OR ADJUSTMENT WITH THE ENGINE OPERATING.
(1) With engine idling, remove the hose from the PCV valve. If the valve is not plugged, a hissing noise will be heard as air passes through the valve. A strong vacuum should also be felt when a finger is placed over the valve inlet.
(2) Install hose on PCV valve. Remove the make-up air hose from the air plenum at the rear of the engine. Hold a piece of stiff paper (parts tag) loosely over the end of the make-up air hose.
(3) After allowing approximately one minute for crankcase pressure to reduce, the paper should draw up against the hose with noticeable force. If the engine does not draw the paper against the grommet after installing a new valve, replace the PCV valve hose.
(4) Turn the engine off. Remove the PCV valve from intake manifold. The valve should rattle when shaken.
(5) Replace the PCV valve and retest the system if it does not operate as described in the preceding tests. Do not attempt to clean the old PCV valve. If the valve rattles, apply a light coating of Loctitet Pipe Sealant With Teflon to the threads. Thread the PCV valve into the manifold plenum and tighten to 7 N·m (60 in. lbs.) torque. hope this helps, good luck.
Thank you, I will try that
Those PCV valves are a PITA.
Probably too late for the OP but anyone else looking to change their PCV valve on this Dodge 3.8, I suggest completely removing the firewall side valve cover and working on it at your work bench. Those things don't come out easily.
crwdns2942667:0crwdne2942667:0 9,476
What year is it and what engine does it have?
crwdns2957956:0crwdnd2957956:0 oldturkey03 crwdne2957956:0
2006 dodge grand caravan sxt 3.8
crwdns2957956:0crwdnd2957956:0 Charles Bronson crwdne2957956:0
