headphone jack repair
How do I fix a broken headphone jack?
You dont have to replace the whole logic board. Just buy the headphone jack itself. You will just have to solder just 4 points. However make sure that it is soldered just right and sit flushed. It's a little easier that having to replace the whole logic board and cheaper. Hope this helps you.
The jack is part of the logic board, soldered to it with 4 contacts. Replacement is usually by replacing the entire logic board. I would do a physical inspection and make sure it's not something that can be fixed (jammed contact inside of jack, or re-solderable contact) and if not, replace the logic board:
This webpage has tips and videos on how to repair your headphone jack: http://www.thefakegeek.com/2011/07/headp...
by fitting a new one
crwdns2942667:0crwdne2942667:0 11,857
