Alexandre Fernandes Nicoli, there are a few things that could be causing this. The very first thing I would try is a new battery. Then check the connector, look at it closely and see if there is any definite damage, broken pins etc. If it looks ok and you have a new battery, see if it charges. If not then you have to take the GBA apart. check for lose connections on the charger. Use a multimeter to see if it gets power when you plug it in. The GBA has two fuses, marked F1 and F2 ion the logic board. Check those with a multimeter and see if you have continuity. Replace those as needed. Hope this helps, good luck
Image shows F2. F1 is on the opposite side of the board.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
crwdns2942205:01crwdne2942205:0
What charger did you use before? Did it fit the connector properly?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
