The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
How do I turn Safe Mode off?
My phone randomly goes into safe mode, and I don't know how or why. The first time this happened was after collecting it from a service center.
Please help.
crwdns2889612:0crwdne2889612:0 325
crwdns2944067:012crwdne2944067:0
my fone went into safe mode coz i removed da battery without switching off the fone so i did as guided but it didnt help for my fone, so restarted the fone n the safe mode was gone. Just helping incase the above solution doesnt work. No criticism intended.
What is "Safe Mode" about
my mobile is gone in safe mode and i also done factory data reset but safe mode is not remove, so hoe can i turn off safe mode.
i tried many types of tricks.....
My phone keeps going on safe mode.tried to restart but all in vain
I'm experiencing the same problem right now I'm using samsung j5...let me try it right now!
crwdns2934275:07crwdne2934275:0
crwdns2933315:015crwdne2933315:0
Daren Humphries, one method you can use to get out of Safe Mode is to turn off the phone, remove the battery, and leave it out for a few minutes. When you put the battery back in and power on the phone, Safe Mode should be gone. If it comes back on its own, there could be an app that's causing the problem. Uninstall one app at a time to check which one is giving you trouble.
How to disable Safe Mode
  1. Remove the battery while the device is on.
  2. Leave the battery out for 1-2 minutes. (I usually do 2 minutes to be sure.)
  3. Place the battery back into the S II.
  4. Push in the Power button to turn on the phone.
  5. Let the device power on as normal, without holding any buttons.
Once the device is on the home screen, you should no longer see Safe Mode displayed in the lower left corner.
Hope this helps, good luck.
crwdns2889612:0crwdne2889612:0 116
crwdns2944067:098crwdne2944067:0:
It really worked . thanks
You are welcome. Best of luck to you
It worked for me to! Thank you
worked for me as well :) Holla
Thanx! You're a guru!
crwdns2934275:093crwdne2934275:0
Step 1: Turn off your phone.
Step 2: Now hold and press both “Power and vol+” button until the “S2” screen Shows.
Step 3: And Press Power Button (Only single press – Do not press and hold)
Update
THIS WILL REALLY HELP YOU
crwdns2889612:0crwdne2889612:0 38
crwdns2944067:020crwdne2944067:0:
Thanks a lot mate.. tried it out now.. Got so PIST when this phones goes their own way..turned off the bat, didn`t help! but this with holding both buttons in then pressing the ON button later HELPED..thank you very,very much..
Thx for ur help it worked well
Many thanks worked on an S4 too. Mike
HY my is a galaxy j 100.
It got Into hot water while I was cooking and the day after I switched it on and I found the safe mode thing . I tried the notification part of taping and restarting it but no I couldn't remove it. I tried everything I found on Google but I can't I even restarted it..
I need your help please I can't access important apps .
thank u it worked. however my a700 seems i cannot open the back to take out battery. not sure if battery comes out. thank you very much. any idea y it just goes into safe mode?
crwdns2934275:015crwdne2934275:0
How to disable Safe Mode?
1. Remove battery while device is on.
2. Leave battery out for 1-2 minutes. (I usually do 2 or 3 minutes to be sure)
3. Place the battery back into the u r device.
5. Let device power on without holding any buttons as normal.
~Munish Kumar
crwdns2889612:0crwdne2889612:0 14
o meu assim que coloco a bateria ele automaticamente liga sosinho...
Worked like a bomb except I’m not entirely sure, whether my device was on have a habit for switching it off. Thanks nontherless felt it fit to share my results.
Have. Done it thares a few ways to do it this. Aanser is for battery's that aren't removable switch phone of wait few minutes that worked for me but not for everyone but without any knowledge of. Software a monkey would sort it in seconds just go to you tube
There's more than one solution to this.
I think the best one that I've come across is this one, supplied by Mike T. (well done!):
I've used this method twice now.
I understand that another solution is to take out the battery, then put it back in.
I have not tried this method to sort out the 'safe mode' problem - but I have employed this course bof action when confronted with a 'frozen' screen (currently also twice).
crwdns2889612:0crwdne2889612:0 9
On and off while holding down the vol button. works like gold. thank you all
God bless you and increase your knowledge. Amen
from Share Prayer Ministry International Dublin Ireland.
I did this but no result
My phone went on safe mode I have been trying to restart it but still on it ,I can't take my battery out because it's stacked in my phone please help me
Mine I tried all this method but still no solution and my volume down key is not working. But not stuck.what must I do .please help
Hello Everyone,
The trick worked out for me... thanks a lott...
crwdns2889612:0crwdne2889612:0 7
I was not sure how my Samsung Galaxy S7 Edge got into a Safe Mode, however, Step 1 - Step 3 works for me.
Thank you.
Removing a battery method may also work but I have not tried it. This method is a bit hard for me because I don't have proper tool to open the phone case which is pretty hard to open.
Typically restarting an Android cell phone should get it out of the Safe Mode feature (a battery pull too as it is essentially a soft reset).
If your phone is STUCK in Safe Mode though and restarting it or pulling the battery doesn’t seem to help at all then it could be a hardware issue like a problematic volume key. Mike T. was on the right path here because if the Volume + key is having issues and you press it when booting up your phone you can be loosening it up or in a way show the phone that you are not TRYING to enter Safe Mode intentionally by pressing the Key combination to do so.
So check those physical keys too, it might just be the fix you were looking for. You can read more about this trick and some other tricks that might help at How to fix an Android stuck in Safe Mode. Usually the terrific advice already posted on this page should get your phone out of Safe Mode but if not then one of the tips on that page should definitely help.
After trying everything and nothing seemed to work, I was about to give up, until I saw this comment above. I pushed the volume key a few time to see if I could "loosen" it up, and when I restarted the phone, I got out of the safe mode! WOW!!! Thanks so much for the help!
I tried removing the battery but that didn't work, and tried holding the power button-volume button and that failed also. But, thanks to the comments regarding the volume button, I finally figured out what may be the problem. I have a cover on the phone that fits very tightly, and I wondered if it was pressing on the volume button to the extent that it was actually triggering it. So, I took the cover off, rebooted the the phone, and the Safe Mode was off.
Thank you all so much!
i tried restarting it i tried taking the battery out i tried powering it off and none of then works and theres lots of things i need to do like foreal
Restart the your phone and when Samsung s4 loge come hold menu and tow side light false tow or three time it should come off safe mode
Every device has different way to turn off safe mode. By keeping this thing in mind I decided to share all the possible ways that help you to get rid of this problem:
1. Simpley reboot your device
2. Take battery out of your device
3. Reboot and Press the Back Key
4. Factory reset your device
5. Download Stock ROM and Flash using ODIN
For more detailed information you can check out this guide on how to turn off safe mode on galaxy s3
Ok its well but in this solution not permanent ,then how get safe mode permanent disabled
I do not have much technical knowledge, but I found that the protective case that came with the phone seems to have been constantly putting it in safe mode. When I remove the case, safe mode goes away. It seems to be depressing the volume key.
Why don't you try this on your device:
1. Press the Back Key while rebooting your device
2. First of all turn off your Samsung Galaxy S3.
3. After that turn on the device. When you see the boot animation logo start pressing the back key which is at right side of the device. Keep pressing untill your device successfully boot.
I hope this trick work for your Samsung Galaxy S3 too. In case this tip didn't work for you. You can check this tutorial for more tips:
https://www.whatswithtech.com/how-to-rem...
In case if you don’t end up needing it for its intended purpose, one should know how to get back from an accidental boot into Safe Mode.
Here i found a usefull article on how to turn of safety mode
http://bbcpak.com/2016/09/turn-off-disab...
what about GT-I9060I
Please try this steps:
Step 1: Swipe down the Status bar or drag down the Notification bar.
Step 2: Tap “Safe mode enabled”
Step 1: Press and hold the power key for three seconds.
Step 2: Press Restart.
Step 1: Tap and drag down the Notification bar.
Step 2: Tap “Safe mode is on”
Step 3: Tap “Turn off Safe mode”
If it is continuing to happen you may want to check the volume buttons to make sure they are not sticking when turning the device on causing you to boot into safe mode.
If your phone is still stuck on safe mode after after everything you tried it might be a water leakage inside the system. the first sigh of this happening is if your volume buttons stop working and this is because water is damaging the connection between the motherboard and the button and to solve this is to go to shop to repair it
Daren Humphries crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 1,542,278
