cold water only dribbles out
Hi,when my washer fills with cold water,it only dribbles out.
Hot water is fine....I've checked the incoming water and hoses and everything is fine....could an internal valve be faulty?
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
crwdns2942667:0crwdne2942667:0 671
