The original Blackberry Bold smartphone, featuring various improvements from older Blackberry models.
Why my phone "jum error 102"?
crwdns2889612:0crwdne2889612:0 11
Basically the error message 102 is a .cod file that has been corrupted. Your BlackBerry, being the smart phone that it is (pun intended), refuses to load the corrupted file. To possibly, and I do mean possibly since this option may not always work, you will need JL_Cmder installed on your computer (grab a copy of it at http://www.blackberryfreaks.com/JL_Cmder... and install it . Make sure you install it into the Program Files on your C: drive. Make a mental note of whatever you saved it as since you will need the exact name you gave it), a USB cable and of course your seemingly lifeless BlackBerry.
Step 1
Connect your BlackBerry to your computer with the USB cable.
Step 2
Run JL_Cmder and select Option #2 - Event Log. It may take a few tries to get the software to open, the reason being it takes JL_Commander a while to start up is that it doesn't run until it connects to the filesystem.
Step 3
Scroll to the bottom of the log and look for "JVM Error 102." The line before it should tell you exactly what file is causing the error. It might look something like this. Save/write down the file name somewhere; you will need it later.
Step 4
On your computer, go to Start > Run, and type "cmd" then press the enter key. Dont forget to run as administrator.
Step 5
Change the directory to the JL_Cmder installation folder by typing the following:
cd "C:\Program Files\JL_Cmder\" and press the enter key. If you named your JL_Cmder anything else (mine is JL_Cmder v1.9.0, here is where you may need to type more into the command like this: cd "C:\Program Files\JL_Cmder v1.9.0\")
Step 6
Type the following command to remove the corrupted file:
javaloader.exe -u erase -f FILENAME
Where FILENAME is, type the name of the .cod file I told you to save or write down. Press the enter key.
Step 7
Disconnect your phone from your PC and restart it. Presto! Your BlackBerry should boot up like normal and you can then go make a backup in case it happens again. Hope this helps. Write back on how it went. Good luck.
https://www.blackberryfreaks.com/JL_Cmde... link is empty .. how to get this JL_Cmder ...???
Una crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 9,840
