Repair guides, disassembly, and troubleshooting information for the second-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB of storage. Released in March 2011. Identified by model number A1395 and EMC 2415. Repairs require the use of heat and careful prying.
Actual LCD Cleaner for IPAD
Hi
Please can anybody advise what to use to clean the LCD under the Digitizer
I have noticed that the LCD can become really filthy once the digitizer is removed.
I have tried a soft brush
A micro fibre cloth
Both of these have left some marks on the Screen
im a bit hesitant to test any type of alcohol cleaner
Can anybody advise please, and only if youve tried it not advise on things that MAY work
Thanking you
Ive done a lot of ipad digitizer replacements. Your best bet is to avoid touching or getting it dirty to begin with.....BUT ALAS. It does happen.
Personally i use a VERY clean microfiber cloth. I would not recommend using any solution. Just a nice dry microfiber cloth should get it taken care of.
You do have to be precise though as around the edges you can grab little bits of left over adhesive and pull them across the screen and that will make big marks across it. Just use a little warm breath if need be and polish it as best as you can. Be careful also not to use too much pressure. Light and quick swirls are better than slow hard pushing.
Hope this helps
Blow vapor from your mouth and wrap it gently with the glasses cloth,
just did it and worked
Ali crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,977
