reading fault code f20
my washer stop in the middle of its cycle and reads f20
Take a look at this link :
F20 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
I think it may help you...
If this answer was helpful please remember to mark it accepted.
crwdns2947821:0crwdne2947821:0
I've been struggling with F20 on and off for a year... Cleaned the drain outlet, cleaned the inlet screens and fished a stray sock out from under the seal by the door. Finally noticed a green package of papers inside the bottom access panel on the side of the washer with a description if all the trouble codes and a wonderful diagnostic test.... Found out my washer was getting plenty of cold water and NO hot water at all on 4 of the 5 times I ran the diagnostic. Swapped out the water inlet valve (found step by step video instructions and how to test the old part for continuity on RepairClinic.com- they even had diagrams and schematics). So much better to be positive I fixed the real problem then guessing and randomly replacing parts!
The F20 error code on a washing machine usually indicates a water inlet problem, meaning the washer is not detecting enough water during the cycle. Here's a step-by-step guide to troubleshoot and resolve the issue:
If you’ve gone through all these steps and the F20 error persists, it’s best to contact a technician. The issue may involve more complex components like the control board.
By addressing these potential causes, you should be able to resolve the F20 error and get your washer back in working order. Let us know how it goes!
crwdns2942667:0crwdne2942667:0 18,262
