The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
button touch buttons not working
I got my phone wet. Not hing worked. So I pulled it apart and cleaned it all up because it had salt stains. Now everything works except for my buttons down the bottom on my Samsung galaxy s3. Is there anything I can do to fix it so they work again
I will stress that if your phone was submerged in salt water make double certain that you do an exceptional job cleaning everything or the phone wont last long at all, here is the part you need, https://www.gounlock.com/details.php?ite..., but it could also be where this part plugs into your motherboard if it's corroded so I would double check and do a good cleaning with alcohol and a toothbrush, use these cleaning methods they are for an Iphone but it shows how to stop corrosion, Repairing iPhone Liquid Damage, here is a teardown guide also for your Gallaxy, good luck. Samsung Galaxy S III Teardown
crwdns2886500:0iPhonecrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937803:0crwdne2937803:0
1 - 2 hours
crwdns2886500:0Samsung Galaxy S IIIcrwdne2886500:0
crwdns2937801:0crwdne2937801:0
crwdns2947631:0crwdne2947631:0
crwdns2947633:0crwdne2947633:0
This could be a Hardware issue. However, let do a quick reset and see how this works out:
Go to Settings
Select Apps
Select All (Look for ALL on top menu or swipe to the right to get to ALL)
Select Google Services Framework and tap Clear Data.
Turn off (shut down) your device and turn it back on.
Test the phone to see if it will black out again.
Hardware issue:get new here
Does the phone have any physical damages?
Here Is The Solution Samsung Galaxy S3 Touch Keys Not Working 100% Tested Solution
he everyone ijus wanna say tht my Samsung galaxy s3 back button and main button and option stooped working and I believe tht I was using my ponw when it was raining and if anyone see this plzz reply and say if it is rain or other problems and thku and have a saf eday
mean"i jus wanna" nd "I was using my phone when it was ....."
Adrian crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 30,457
