Guides and repair information for Logitech computer speakers and desk speakers.
Looking for replacement battery for Logitech MM50 S-0173A Speakers?
I have a Logitech MM50 S-0173A speaker dock. Anyone have any clues as to where I can find a replacement battery for these iPod speakers from Logitec? I've tried Logitech - their answer is "we no longer make this device" - not a great deal of help!!. The battery is about 1/2" dia x 2" lithium, 3.7 volts.
Thanks
Need to know the model number of the battery to find it. Ralph
OK try this one. Scroll down the left side and you will find a possible battery for your needs. Ralph
http://www.surplustraders.net/a/0696.sht...
I did a quick search on ebay http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
Update (04/26/2010)
It uses any 18650 battery. They can be found in many consumer goods. IE Laptop batteries.
here is the replacement battery for Logitech MM50
http://www.batteryforum.org/t887-logitec...
Like EKWF said (#comment229709), a Logitech mm50 battery contains a single 18650 cell. Its battery cell is soldered to a protection circuitboard, and surrounded by insulator skin (heat shrink tube). Its battery protection board connects to mainboard through three wires: black (battery negative), red (battery positive), and white (NTC thermistor between black and white, if I recall correctly, but check yours to be sure). As simply one cell comprises its battery, it can be re-celled fairly easily. This battery is discussed in some detail, with pictures, on iLounge. (Topic: Logitech mm50 & Pure Fi anywhere batteries)
Logitech mm50 has an inlet for an external power supply. Its power plug is a coaxial barrel, outer diameter 3.5 mm, inner diameter 1.1 mm (approximate), insertion depth 8 mm. (You might scavenge a perfect replacement barrel plug from Nokia equipment.) Its original power supply is nominal 12 VDC, 1.5 A, centre positive.
If you are looking to make a replacement power supply (repurpose an AC adapter and splice a plug), then your replacement MUST have regulated output. (Non-regulated "old" style wall warts, big and blocky with a hot transformer, output a wide range around nominal rating. A piece rated "12V" might output nearly 20V while not loaded. Power capacitors in mm50 are rated 16V.) I suppose a one amp supply could suffice, but not much less than that: mm50 draws more than one half ampere when quiet and idle and iPod is not present.
flipinoz crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 6,972
