Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
Kenmore 80 series drive tub seal replacement
I replaced the tub seal on my Kenmore direct drive washing machine as shown on this youtube video (Whirlpool/ Kenmore Washer Repair: Drive Tub Seal Replacement (part #383727) - YouTube). When I had removed the outer tub I had noticed caked up dirt/grease along the bottom of the outer tub near where it would contact the inner tub and mounting stem. Thinking this was dirt, I cleaned it off and replaced the tub seal. I've put everything back together and now the tub makes a high pitched noise while in spin mode and does not spin correctly. Was I wrong to have cleaned that dirt off or was I supposed to grease the seal/mounting stem or space between the two tubs? What kind of grease is used for this?? Any help would be appreciated!!
I do not think that it was grease. It should not need any. I would double check for proper alignment of the inner tub. It does sound like it may be to tight on the drive shaft or out of alignment.
Luis crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,525
