Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
iPhone 4 Disabled but cant connect to iTunes to fix it
I just got an iPhone 4. I set it up with a passcode so no one would go through it. My friend tried to unlock it, and now it's disabled to the point where I have to connect it to iTunes to enable it. I didn't have a chance to connect it to my iTunes before he did that. When I try to connect it to iTunes, it says that I have to remove the passcode, but I obviously can't. How do I fix this?
crwdns2889612:0crwdne2889612:0 400
crwdns2944067:035crwdne2944067:0
Thanks a million asf -- nothing else worked, not hard-reset or DFU mode (I couldn't get my iPhone 5 to enter dfu at all!) but that simple tip worked perfectly!!
i need to fix it soon
my iphone is disabled and not connected to itunes plzzzz help me....some body
What if i dont have a laptop
good after noon i really need some help can you tell me how to unloock my iphone without a cumputer hope to heare back from you.
crwdns2934275:030crwdne2934275:0
crwdns2933315:011crwdne2933315:0
Thomas, try going into DFU Mode and restoring your phone:
  • Connect your iPhone to your computer.
  • Turn your iPhone off.
  • Press and hold the power button for 3 seconds.
  • While continuing to hold the Power button, press the home button for 10 seconds.
  • Keep holding down the home button, and release the power button for another 10 seconds.
  • iTunes should now detect the iPhone in recovery mode. Press OK, and restore your iPhone.
  • Now you can release the buttons. If you have not reached this point, then you have not entered DFU Mode.
crwdns2889612:0crwdne2889612:0 168
crwdns2944067:051crwdne2944067:0:
thank you so much this helped and worked :D
even in DFU mode I still cant connect to iTunes keep getting error 9006 please help
tika, try this from Apple:
There may be third-party software that modifies your default packet size in Windows by inserting a TcpWindowSize entry into your registry. Your default packet size being set incorrectly can cause these errors. Contact the manufacturer of the software that installed the packet size modification for assistance or follow this article by Microsoft: How to reset Internet Protocol (TCP/IP).
Verify that access to ports 80 and 443 are allowed on your network.
Verify that communication to albert.apple.com or photos.apple.com is not blocked by a firewall, or other Internet security setting.
Discard the .ipsw file, open iTunes and attempt to download the update again. See the steps under Advanced Steps > Rename, move, or delete the iOS software file (.ipsw) below for file locations.
Restore your device while connected to a different network.
Restore using a different computer."
THX, it really helped me
off find my iphone
crwdns2934275:046crwdne2934275:0
I fixed my device using this guide - iPhone is Disabled Error Fix
crwdns2889612:0crwdne2889612:0 34
its stuck on the connect to itunes screen i connected it to my computer but its not even being detected now what should i do
how to get on dfu mode???
here tell you to enter the DFU mode
oldturkey03 my Iphone did that to and my aunt did this thing and it worked it is a video
try this
http://www.bing.com/videos/search?q=when...
Pls my iphone home button is broken.... How else can i get into the recovery mode with my iphone disabled and requesting for itunes
All you have to do is you have to press and hold the home and lock button and the up volume button
crwdns2889612:0crwdne2889612:0 12
Basically just power off your phone for 10 seconds and then switch it on and then connect it to your laptop or computer and then install you ios again and it should work!
My iPhone is and cnnect to iTunes pales help
Here's the easiest Guide if your iPhone is disabled - You can fix this error in 5 steps https://www.youtube.com/watch?v=O4Tmt3IW...
my home button won't work, what to do?
Have you found a solution to this yet?
Try to enter DFU mode and connect your device to PC, make sure all the drive work fine.
If you enter DFU mode to unlock iPhone, your data will lost, if you have backup, you need restore from backup.
Apart from the DFU mode can unlock iPhone, you can use your iTunes or iCloud to unlock iPhone, but same as DFU mode, you will loss all data in iPhone, but you can restore from backup after that you have unlocked iPhone.
If you don’t want loss data and your iPhone system is iOS 8 or precious, you can use Siri to unlock iPhone without password for free. This method is suitable for only a few iPhone.
Or you can use Eelphone iPhone Unlock to unlock your iPhone in steps.
Hi, facing such a situation, you can put your iPhone into recovery mode and then try to restore it with iTunes. If failed, please continue to apply iCloud to remotely erase your iPhone. Doing so can also fix the problem, but this method requires “Find My iPhone” to be enabled on your device. Alternatively, using an iPhone unlocking tool is the other great solution to this problem. Many users have reported that such a tool called Joyoshare iPasscode Unlocker has the ability to fix such issues without any limitations and difficulty. Hope these ways can be useful to you all.
If your iPhone 4 is disabled and won't connect to iTunes, enter Recovery Mode by holding the Home button while connecting to a PC. Update iTunes, then select Restore to erase the device. If Find My iPhone is enabled, erase it via iCloud.com. Third-party tools can also help.
Mobile lost in 2016
@vishwajeet74746 Dude, if you lost your phone that long ago, let it go, it's gone, man.
Put your iPhone 4 into Recovery Mode by holding the Home button while connecting it to your computer. Then open iTunes and click Restore. This will erase the passcode and let you use the phone again — but all data will be lost.
Thomas crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 171
crwdns2942667:0crwdne2942667:0 319,117
