How do I figure out the code for the radio?
I just had to replace the battery in my husbands civic that i have been driving and it says to enter a code for the radio. I have no clue what the code is and I don't have the operators manual and he is away with no phone for two more weeks. Does anyone have suggestions? I have tried several different combinations but none are working.
crwdns2889612:0crwdne2889612:0 20
crwdns2944067:017crwdne2944067:0
I need help I did this steps of holding one and six and hitting the power button it work my radio turned on however after about 2 to 3 minutes it cuts back off and I have to go through those steps again can anybody help me with this please please please thank you thank you
Nesito sial aguien tine el codigos de honda civid 2006 la serie es 400288850 por favor no tengo manual esta bloquedao el radio
Hi my honda civic radio has been locked please help me to unlock this the vehicle no.JHMFD16717S407136
Radio no. 30023801
The original radio codes can be found online at : https://www.radiocodescalculator.com/
Hi my honda civic radio has been locked please help me to unlock this the vehicle no. JHMFD16756S413147
Radio no. 30011592
crwdns2934275:012crwdne2934275:0
crwdns2933315:09crwdne2933315:0
Misty, give this a try:
  1. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn car to ON II(radio powers up)
  2. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn radio off
  3. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)
  4. Hold 1 & 6 buttons on radio
  5. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)While still holding 1 & 6, turn radio on
  6. Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Write down the 8digit number that should display
Call your Honda dealer and give them those numbers. Or just follow the directions on here. Hope this helps, good luck.
crwdns2889612:0crwdne2889612:0 8
crwdns2944067:07crwdne2944067:0:
This is only for US Vihicle, how about japan? Thanx bro
2008 Honda Civic. Sticker with CODE is on the OUTSIDE left side of the opened glove box.
OR, much easier...
Just go here: https://radiocodevault.com/honda/
They give you the unlock code all online via email, and no need to make an appointment at the dealership.
But why vin number is not valid
I opened my glove compartment and was on the left outside of the glove box which has now been exposed by opening
crwdns2934275:02crwdne2934275:0
Got a working radio code for my Honda from https://radiocodevault.com/honda/
Was quite the blessing to finally find a place that made the process really easy. Hope it helps ;)
crwdns2889612:0crwdne2889612:0 12
Worked on my civic, thnx
Got it for me too
gracias it works
THIS WORKS-
ANSWER IF RADIO LOCKED. I have a Honda civic 2009, Radio was locked.
Hold down 1 & 6 then switch on radio. you will get a U - 4 digit code & L -4 digit code....write these 8 numbers down.
put these numbers into:
https://hondaradiocodes.com/ . ie: U1302 L2930
including the letters. it will return a 5 digit number....I put this Number into radio for unlock code. IT WORKED
There’s really 2 ways to do this if you don’t have the unlock code:
1) You can go to a dealer and pay around $75-$300 in “labor”. Or maybe if you’re lucky get someone to do it for free, but they almost always bill out at 30 minutes labor from what I’ve heard from others.
2) Use an independent radio unlocking service. A reputable one that some others have mentioned is https://radiocodevault.com/honda/ They just need your VIN #, and some other information.
Best of luck.
crwdns2889612:0crwdne2889612:0 9
thank u, I saw this posted on a few different questions on this site, and this is the only place that actually ended up helping me to fix it. That radiocode site was great, they emailed me back my code real fast with extra instructions on how to clear all the errors. thank you again
You just need the serial number in order to obtain the unlock code for your radio.
Just press and hold the 1&6 buttons at the same time, while turning your radio on.
The serial number should then display. And then type it into the form at http://radiocodevault.com/honda/
You’ll receive the unlock code in your email.
Pretty simple stuff, and avoids a dealership trip.
Don’t make things more complex then they need to be.
Oh and sometimes it will say ERR, or ERR5, ERR7. You’ll just need to disconnect the car battery for 30-45 minutes and then try the serial number trick again, and it should then show the serial number. Then go to the radiocodevault site and enter it.
Thank you! It worked, the radio is now working again :D
Thanks for posting these instructions, my stereo is functional again
Don’t keep trying to guess different codes! It can lock it up forever… and then you are really screwed.
Here is what you need to do:
Step 1: Find the VIN# of your car.
Step 2: Follow the instructions on this site and enter your VIN#
Step 3: Receive the unlock code in your email
Enjoy
It is in the glove box on a sticker.
crwdns2889612:0crwdne2889612:0 7
Thank you :) this is the easiest way and this worked perfect for me. I had entered code wrong 5 times before this and was nervous because I did not know how many more times I could enter wrong without getting locked out completely. Thank you again.
Well I had no sticker in the glove box, butI got lucky, I found a owners manual in the glove box and the previous owner had wrote the radio code down there...
2008 Honda Civic. Sticker is on the OUTSIDE left side of the opened glove box.
I got a honda radio code here: https://radiocodevault.com/honda/
Turn radio off.
Hold 1&6 button.
While the 1&6 are depressed, hit volume button.
This will show you radio SSN.
Write this number down.
Than visit this site.
https://radio-navicode.honda.com/
Where it says enter code, Try all of the codes this site gives.
The code will display alpha according to the acronym c-o-d-e.
Keep trying the given codes, one of them will work and your radio will turn on.
Don't let Honda Rob u of $400.
#carcriminals
Worked, thank you so much!!!
holding 1 & 6 and pressing the power button it shows me S/N no code...pls what do i do
Thank you, worked perfect and my radio stations were still on there when I got the five NaviCodes to try!
As the person above said, it's in the glovebox. Mine was on the left hand side, small white sticker about 2" long, the top number (5 digits) is the radio code.
Worked perfectly 2-22-17!
This is the best and easiest answer, assuming you have a sticker inside the glove box with the code numbers.
This doesn’t work for people outside of the USA, I ended up using http://radiocodevault.com/ for unlocking my radio.
I tried the same several times, but it says VIN invalid.
To obtain the unlock code for your Honda radio, you'll need the serial number. Here's how to get it:
  1. Press and hold the 1 & 6 buttons simultaneously while turning on your radio.
  2. The serial number should then display on the screen.
  3. Enter this serial number into the form at https://radiounlocked.com/
  4. You'll receive the unlock code via email.
It's a straightforward process that saves you a trip to the dealership.
If you see "ERR" or "ERR5" or "ERR7" on the screen, disconnect the car battery for 30-45 minutes. After reconnecting, try the serial number trick again to display the serial number, then go to the radiocodevault site and enter it.
Misty crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 74
crwdns2936753:030crwdne2936753:0 285
crwdns2942667:0crwdne2942667:0 258,029
