I used a safety pin (bigger one, about 1.5"), and pushed the pointed pin at the side, pushing the latch that holds the connector on the side.
I just keep doing this on either side, and pull back again. One time after pushing it deep inside, when i pulled it, that side of the broken piece lifted up. So I knew it was possible.
kept doing this until one time the broken piece turned 90 deg. so then i was able to use a thin long nose and pull it out. The whole trial process took ~ 30 mins, with breaks in between. Good thing is since i did that on the sides only, the connector is still ok, and charging still. Just be patient. And yes, at times the pin would bend ...
good luck !
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
112
crwdns2944067:066crwdne2944067:0
I found a great way to "pick" out the broken charger tip. Take a large sewing needle and insert it in a coax cable straight union, $1.50 at Walmart and thread a cap on it. This gives you something to hold onto when picking out the broken tip. Took me about an hour but it eventually came out. Apple iPad was not repairable but we proved them wrong once again.
crwdns2934271:0crwdnd2934271:0 alexpwebster crwdne2934271:0
I put a bit of Crazy Glue on the cable side, put the tip and the cable together, waited for it to dry (like a minute or so), then pulled it out with no problems.
crwdns2934271:0crwdnd2934271:0 saxmenpr crwdne2934271:0
You can take the device to some third party trusted local service center. They can take the broken thing out from the device and fix the issue.
crwdns2934271:0crwdnd2934271:0 John Bright crwdne2934271:0
My husband used a very tiny bit in a battery powered drill and drilled in the middle of the piece stuck in the charging port then wriggled the tip back and forth. The piece came out immediately without any damage. Ellie Cardillo
crwdns2934271:0crwdnd2934271:0 ebc0017 crwdne2934271:0
Had the same issue. Got eyeglass repair kit and the tiny point worked perfect. Took less than a minute!
crwdns2934271:0crwdnd2934271:0 likepar06@gmail.com crwdne2934271:0
crwdns2934275:061crwdne2934275:0
