crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Keyboard/Keys Not Responding
If the keys on the keyboard are missing, broken, or not responding.
Keys Are Stuck In Place
When keys can't be pressed, there may be something below the physical key holding it up. To fix this, remove the key and make sure nothing is stuck below it. You may need to wipe off the area underneath. Once it is sufficiently clean, snap the key back into position.
Keys Are Missing
If keys on the keyboard are missing, replace them.
Computer Won't Boot
Your computer does not load the operating system and instead takes you to an error message.
RAM is Dislodged
The RAM can be dislodged from its original positioning at times. When this happens, you will need to access the RAM and position it correctly
Not Enough RAM
If your computer crashes during normal operation, crashes during memory-intensive tasks, or beeps and will not boot up, this means you have bad RAM or that you do not have enough RAM. Install or replace RAM in your laptop.
Computer System Lag
Your laptop is not running at the normal speed.
Battery Failing
If the computer runs slower than usual, you should check the battery to see if it is still functioning normally or if it is at the end of its lifecycle. If the battery is failing, purchase a new battery and replace it with the new one.
DAN Filipecs
crwdns2935283:009/14/18crwdne2935283:0
57 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
McKendree University, Team S1-G3, Quinn Fall 2018 crwdns2935289:0McKendree University, Team S1-G3, Quinn Fall 2018crwdne2935289:0
MCKU-QUINN-F18S1G3
crwdns2935297:036crwdne2935297:0
i have changed windows os, then function keys stopped working! how can i fix that?
shkam - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 931
