crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Roomba stopped moving
The Roomba stops moving in the middle of vacuuming.
Front Wheel is Stuck
If the front wheel has trouble turning, the wheel may have debris lodged in the axle. Remove the wheel and clean the wheel cavity. Also remove the wheel from its housing and clean the axle. If the wheel is still not working, it may be broken and need to be replaced.
Placeholder Text
Side Wheel is Stuck
Place the Roomba on a flat surface and restart the clean cycle. If any errors occur on a flat surface, check the wheel for any clogged debris that is preventing the wheel from moving. If the wheel still does not work, then it may be broken and need to be replaced.
 Placeholder Text
Roomba is moving strangely
Constantly spinning uncontrollably or is not able to sense drop offs.
Roomba is Spinning in Circles
Pick up the Roomba and place it in the middle of the room. Restart the clean cycle. If the problem continues, the wheels could be obstructed and should be checked for debris.
  1.        Inspect the wheels for debris.
  2.        Manually turn the side wheels and push them down to clear any debris in the wheel wells.
  3.        Push/tap the bumper to ensure spring compression and to clear any debris.
  4.        If this does not solve the problem, use compressed air to clear all remaining debris.
 ''Placeholder Text
Roomba has decreased in cleaning performance
Will not vacuum as efficiently as before.
Brushes and/or Filter Are Dirty
The Brushes and Filter often get blocked up, which leads to a decrease in the performance of the Roomba.
Remove the brushes to clean them.
In order to clean the filter:
  1.        Remove the dirt bin.
  2.        Open the Dirt bin door using the yellow tab.
  3.        Pull the yellow tab upwards.
  4.        Clean the filter with compressed air.
  5.        Replace the filter, close the door, and reinsert the Dirt Bin.
 Placeholder Text
The Roomba's Lights Are Flashing
The Roomba's lights are blinking, displaying an error, or saying "charging error".
The battery is not connected. Make sure that you removed the battery pull-tab. Once that is done, take off the bottom cover of your Roomba to reinstall the Roomba's battery.
Placeholder Text
Your Roomba needs to cool down or let it recharge for awhile while its cooling down.
Placeholder Text
You need to reset the Roomba's software. In order to do this, hold the two buttons above and below clean simultaneously for 10 seconds, then try charging your Roomba again.
Placeholder Text
See 'Blinks Three Times'. It can be resolved with the same solution as number 3.
Placeholder Text
The battery of your Roomba is too warm or it's overheating so you need to let your Roomba cool down for about an hour and then try charging it again.
Placeholder Text
The battery of your Roomba is not cooling which means that you need to Let your Roomba cool down for about an hour and or more until it starts to charge again.
Placeholder Text
Bryson Britten
crwdns2935283:002/13/20crwdne2935283:0
51 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
University of North Texas, Team S1-G5, Thomas Spring 2020 crwdns2935289:0University of North Texas, Team S1-G5, Thomas Spring 2020crwdne2935289:0
UNT-THOMAS-S20S1G5
crwdns2944067:014crwdne2944067:0
Buenas tardes tengo problemas con el cepillo lateral de Romba 675 , no funciona ya lo limpie siguiendo los pasos del manual y sigue sin funcionar, ? QUE RECOMIENDAN HACER , se compro apenas en diciembre 2020. ? tiene garantía?
Jose Antonio Barrera - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Roomba does not dock — not recognizing docking station; runs into it and pushes it around.
Tom Breese - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My rhoomba is giving the error to clean brushes. I clean the brushes and restart. It runs for about 4 minutes and then stops and gives the clean brushes error again. What do I need to do???
Donna Baker - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My roomba is brand new. It only spins in circles and does not move.. what can I do? I have already bumpped the bumpper, checked the wheels for debirs… it states error 9 nothiing works
Bertha - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 6,836
