iPod won't turn on
No matter what you do, you can't get your iPod to turn on.
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, it must be replaced. Replacing the battery requires soldering.
Bad control electronics
If absolutely nothing happens, it is possible that your iPod is not receiving your instructions because the electronic portion of the control buttons are bad. Replacing the control buttons requires replacing the logic board (for the hold switch/headphone jack) or the headphones (for playback control).
Bad logic board
If your iPod does nothing when plugged into a computer, the solution most likely lies in replacing the logic board. Transferring your old battery to your new logic board requires soldering.
No audio or distorted audio
Your iPod turns on and appears to work, but when you plug in headphones or speakers, the audio doesn't play properly.
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPod with another set of headphones or speakers just to make sure that the problem is with the iPod.
Bad audio jack
The most likely cause of audio output problems on iPods is a bad audio-out jack. Unfortunately, this jack is permanently affixed to the logic board. Therefore, you will need to replace the logic board.
Other problems
Other issues that may hinder the operation of your 3rd Generation Shuffle.
Corrupted software
Sometimes, a reset and restore will fix a sad iPod. Connect your iPod to your computer and use iTunes to restore the iPod. Restoring the iPod will erase everything on it, so make sure everything on the iPod is stored elsewhere prior to restoring. Sometimes it may be necessary to restore the iPod several times before it works properly. If you are unable to restore your iPod using iTunes, you can hard reset your iPod. iPod Shuffles can be reset by doing the following procedure: unplug from computer (if connected), move the hold switch to the off position, wait five seconds, then move the hold switch to either the play in order or shuffle position. At this point, your shuffle should be reset.
Bad logic board
If restoring the iPod didn't work, the cause is likely a problem with the logic board. There's not much to troubleshoot here. Basically, the only option is to replace the logic board.
Bad memory
One of the nice things about iPod Nanos is that their flash memory is nearly impervious to damage from dropping the iPod. Replace your logic board for new memory.
crwdns2944067:04crwdne2944067:0
i phone 4s earphone is compatable to iphone 3rd gen shuffel?. for my ipod its not working. is there any problem in my ipod?
Sagar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have a ipod shuffle 3rd gen i have earphones but the remote on it doesn't work i cn hear the music through the earphones but i cant cahnge or turn the music up... please i need help!!
lobby_site - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you. 3rd Gen iPod shuffle...now working fine again...after sitting a drawer "broken" for 6 years !
David S - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 26,488
