iPod won't turn on
No matter what you do, you can't get your iPod to turn on.
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, it must be replaced. Replacing the battery requires soldering.
Bad control electronics
If absolutely nothing happens, it is possible that your iPod is not receiving your instructions because the electronic portion of the control buttons are bad. Replacing the control buttons requires replacing the logic board.
Bad logic board
If your iPod does nothing when plugged into a computer, the solution most likely lies in replacing the logic board. Transferring your old battery to your new logic board requires soldering.
No audio or distorted audio
Your iPod turns on and appears to work, but when you plug in headphones or speakers, the audio doesn't play properly.
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPod with another set of headphones or speakers just to make sure that the problem is with the iPod.
Bad audio jack
The most likely cause of audio output problems on iPods is a bad audio-out jack. Unfortunately, this jack is permanently affixed to the logic board. Therefore, you will need to replace the logic board.
Other problems
Other issues that may hinder the operation of your 2nd Generation Shuffle.
Corrupted software
Sometimes, a reset and restore will fix a sad iPod. Connect your iPod to your computer and use iTunes to restore the iPod. Restoring the iPod will erase everything on it, so make sure everything on the iPod is stored elsewhere prior to restoring. Sometimes it may be necessary to restore the iPod several times before it works properly. If you are unable to restore your iPod using iTunes, you can hard reset your iPod. iPod Shuffles can be reset by doing the following procedure: unplug from computer (if connected), move the hold switch to the off position, wait five seconds, then move the hold switch to either the play in order or shuffle position. At this point, your shuffle should be reset.
Bad logic board
If restoring the iPod didn't work, the cause is likely a problem with the logic board. There's not much to troubleshoot here. Basically, the only option is to replace the logic board.
Bad memory
One of the nice things about iPod Nanos is that their flash memory is nearly impervious to damage from dropping the iPod. Replace your logic board for new memory.
I have three ipad shuffles that will no longer turn on.  Where can I get these repaired
cathy koon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I hook up the iPod Shuffle 2nd Gen to my MacBook Pro, Turn on iTunes, it says this iPod is open in another window. I've restarted the MacBook, but I still get the same message. I click the eject button to eject the iPod, and it goes into loading (thinking) mode, and can't get out of it. I've tried everything I could to reset the iPod but had no success. Please help.
Eric - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi Eric. Just come upon this site, hence late reply. My Mac started doing this to me recently whilst trying to download to my iPad air 2. After trying a number of so-called solutions, I just happened to disconnect both my mac and iPad from my VPN, and hey Presto. I obviously do not know if this solution pertains to you, but if you are running a vpn, give it a try. Regards, Robert.
BTW, the "other" window referred to by your computer, is Finder. But u probably knew that! Lastly, if & when my mac refuses to eject my iPod, I default to switching off my computer before manually ejecting, just in case.
Robert Carter - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 188
crwdns2942667:0crwdne2942667:0 65,281
