iPod won't turn on
No matter what you do, you can't get your iPod to turn on.
Hold switch on
Before delving into the guts of your iPod, check to make sure the hold switch isn't activated. If the hold switch is on, the iPod will ignore any input on the touch wheel and refuse to do anything. If your iPod's problem isn't so easily solved, read on.
Drained/bad battery
If your iPod won't turn on, especially if it has not been used recently, you may simply have a drained battery. Plug your iPod into your computer or AC adapter and see if anything happens. Ideally your iPod will recognize it has been connected to a power source and charge its battery. If it will no longer charge, it must be replaced with a new battery.
Bad logic board
If your iPod does nothing when plugged into a computer, the problem most likely lies in the logic board. We offer instructions for installing them.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you hold the iPod up to your ear you should be able to hear the hard drive spinning. If the iPod sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced.
No audio or distorted audio
Your iPod turns on and appears to work, but when you plug in headphones or speakers, the audio doesn't play properly.
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPod with another set of headphones or speakers just to make sure that the problem is with the iPod.
Bad audio jack
The most likely cause of audio output problems on iPods is a bad audio-out jack. Unfortunately, the audio jack is soldered to the logic board. Therefore, fixing your audio issue will require a new [/search/iPod+2G+logic+RAM|logic board].
iPod won't turn on
Hold switch on
Drained/bad battery
Bad logic board
Bad display
Bad audio jack
The most likely cause of audio output problems on iPods is a bad audio-out jack. Unfortunately, the audio jack is soldered to the logic board. Therefore, fixing your audio issue will require a new logic board.
Sad iPod icon on startup
The iPod displays an image of a sad iPod when turned on
Corrupted software
Sometimes, a reset and restore will fix a sad iPod. Connect your iPod to your computer and use iTunes to restore the iPod. Restoring the iPod will erase everything on it, so make sure everything on the iPod is stored elsewhere prior to restoring. Sometimes it may be necessary to restore the iPod several times before it works properly. If you are unable to restore your iPod using iTunes, you can hard reset your iPod. 2nd generation iPods can be hard reset by booting while holding the menu and play/pause buttons. This should result in a quick dark screen followed by the standard Apple boot graphic.
Bad logic board
If restoring the iPod didn't work, the sad iPod is likely caused by a problem with the logic board. There's not much to troubleshoot here. Basically, the only option is to replace the [/search/iPod+2G+logic+RAM|logic board].
iPod won't turn on
Hold switch on
Drained/bad battery
Bad logic board
Bad display
Bad audio jack
iPod won't turn on
Hold switch on
Drained/bad battery
Bad logic board
Bad display
Bad audio jack
Corrupted software
Bad logic board
Folder icon appears on startup
The iPod displays an image of a folder when turned on.
Bad hard drive or cable
One of the best methods to diagnose a failing hard drive is to listen to the drive. If you put your iPod up to your ear, you should hear a smooth-sounding whir of the hard drive spinning. Any loud clicking or grinding sounds may mean that your iPod's drive is failing. If you don't hear anything, the drive is not getting power or is very damaged and can't spin up. In this instance, replacing the hard drive cable first is a good idea. Then, if the problem persists, replace the hard drive. Browse our [/search/ipod+hard+drive+GB|hard drives] and check out our [/info/ID-your-iPod|iPod ID page] for compatible drives.
The iPod either boots to an Apple logo and freezes or continuously reboots.
Bad logic board
This is likely the cause, and the [/search/iPod+2G+logic+RAM|logic board] must be replaced.
Bad audio jack
Corrupted software
Bad logic board
One of the best methods to diagnose a failing hard drive is to listen to the drive. If you put your iPod up to your ear, you should hear a smooth-sounding whirr of the hard drive spinning. Any loud clicking or grinding sounds may mean that your iPod's drive is failing. If you don't hear anything, the drive is not getting power or is very damaged and can't spin up. In this instance, replacing the hard drive cable first is a good idea. Then, if the problem persists, replace the hard drive. Browse our [/search/ipod+hard+drive+GB|hard drives] and check out our [/info/ID-your-iPod|iPod ID page] for compatible drives.
iPod doesn't boot past Apple logo
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
Bad logic board
Bad audio jack
Corrupted software
Bad logic board
If restoring the iPod didn't work, the sad iPod is likely caused by a problem with the logic board. There's not much to troubleshoot here. Basically, the only option is to replace the logic board.
One of the best methods to diagnose a failing hard drive is to listen to the drive. If you put your iPod up to your ear, you should hear a smooth-sounding whirr of the hard drive spinning. Any loud clicking or grinding sounds may mean that your iPod's drive is failing. If you don't hear anything, the drive is not getting power or is very damaged and can't spin up. In this instance, replacing the hard drive cable first is a good idea. Then, if the problem persists, replace the hard drive. Browse our hard drives and check out our iPod ID page for compatible drives.
Bad logic board
This is likely the cause, and the logic board must be replaced.
Luke Soules
107,855 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072,955crwdne2935297:0
mi ipod classic modelo A1238 se pone en la pantalla que esta cargando y dice no desconectar aunque la figura de la pila marque llena, lo desconecto y se pone que esta listo pero al moverle los botones no hace nada, que podra ser.
Cesar Sanmiguel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 106
crwdns2959996:0crwdne2959996:0 39,867
