crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Printer Won’t Turn On
The printer is not receiving power and the LED status light is not on.
Power Switch Is in the Off Position
Make sure that your thermal printer is turned “on” by checking the power switch at the back of the printer. The LED status light will also glow solid green if the printer is on.
Power Sources May be Disconnected
Check connections from the wall outlet to the power supply, and from the power supply to the printer. If there are no irregularities with the power cord and it is plugged into the wall, disconnect the printer from the outlet for 30 seconds and then plug it back in.
Paper Won’t Feed
Paper is not being fed into the printer and the status light is flashing red.
Printer is Out of Paper
Ensure that the printer is loaded with a roll of paper. Follow the instructions for loading rolls that is on the inside of the printer and then press the feed button to resume printing.
The Printhead is Open
Close the top cover before attempting to print. Once the printhead is closed, press the feed button to resume printing.
Printer Producing Blank Labels
There is no print on the labels.
Labels are Not Loaded Correctly
Check to see if the labels are in the printer backwards. To figure out which side the printer prints on, scratch the surface of the blank label with your nail and it should leave a black mark.
Misalignment of Print on Labels
When printing a label the print on the label is ‘off the page.
Printer May Need Calibration
To calibrate the printer:
1. Load the printer with the labels for your application
2. Power on the printer.
3. Press and hold the Feed Button until it flashes two times then release it.
4. Allow the printer to complete feeding labels and printing a sensor profile.
5. The printer should now be calibrated. Press the feed key and one label should be
issued each time.
Steps from Zebra documentation
Image Does Not Look Right
The printed image does not appear as expected (ie. print on labels are too dark or light).
Printhead is dirty
The printhead could be dirty. Zebra recommends purchasing a cleaning pen. Be sure to always use a new cleaning pen, as an old one can carry contaminants from previous usage and damages the printhead.
Caution: ''The printhead becomes hot while printing. To protect from damaging the
printhead and risk of personal injury, avoid touching the printhead. Use only the cleaning pen to perform maintenance.''
1. Rub the cleaning pen across the dark area of the printhead. Clean from the middle to the outside. This will move adhesive transferred from the edges of media to the printhead
outside of media path.
2. Wait one minute before closing the printer.
Printhead is under temperature
If the indicator light is flashing amber, your printhead is under temperature. Continue printing while the printhead reaches the correct operating temperature.
Print Darkness Needs to be Adjusted
The darkness setting might need adjusting in the driver on your computer.
On the General tab of the driver window, click on printing preferences
Expand Device Options and then expand Head Settings…
Select Darkness Wizard and click the Settings button
Follow the instructions in resulting window
Incompatible Media
The media is incompatible with the printer. Make sure your media is recommended for your application, and use Zebra approved labels and tags.
Printhead has Worn Out
The printhead could be worn out due to friction between the printer and the media and may need to be replaced.
Platen Needs Replacement
The platen (driver) roller may be losing traction due to foreign objects attached to its surface, rubbery smooth surface has become slippery, or there is damage to the normally smooth surface. You may need to replace the platen.
There Are Blank Vertical Lines on Labels
The printer produces labels with blank vertical lines.
Printhead is dirty
Printer May Need to be Calibrated
issued each time.
A Self-Test May be Required
1. With the printer power off, press and hold the feed button while you turn on the power. Continue holding the feed button down until the printer begins flashing green (pause mode). The printer will flash several different color and flashing combinations prior to flashing only green. Release the feed button. The printer prints out a listing of its current configuration. After printing the label, the printer will automatically enter a diagnostic mode in which the printer prints out a literal representation of all data subsequently received. To exit the diagnostic mode and resume printing, turn off and then turn
on the printer.
2. With the printer power on and top cover closed, press and hold the feed button for several seconds. The green status LED will flash a number of times in sequence. The explanation at the right (Action) shows what happens when you release the key after the specific number of flashes. (See Zebra ZP 500 User Guide) for explanataion of codes.
crwdns2944067:05crwdne2944067:0
When trying to calibrate, it won’t do it correctly and the feed button will start blinking red.
Do you know what could be causing this issue?
Oscar Ramirez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm having the same problem ??? Does anyone know why???
Susan Hance - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same here, won’t calibrate.
Nathan Stein - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Why do all of my labels print horizontally and not vertically? I'm trying to print off FedEx labels but it keeps printing horizontally.
Nick - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hold the power button down for 10-20 seconds to factory reset the printer. That fixed the issue for me.
Seth Deloney - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
