crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Drag System Problems
Drag Will Not Tighten Up
I would like to tighten my drag; however, the line keeps pulling out.
Replace Drag Gears
If your drag will not tighten, you may need to replace the drag gears.
Frozen Drag
I am trying to cast my reel; however, the drag seems frozen.
Dirt Build Up
You may need to clean the dirt and debris out of the drag system. Another possible solution is to lubricate the drag system.
Line Snaps
My line keeps snapping when I catch fish.
Drag Not Properly Set
Adjust the setting on the drag. Without properly setting the drag, the line will snap because there is too much tension on the line.
Handle Problems
Handle Will Not Crank
I want to crank my handle; however, the handle won't crank.
Replace Handle
If your handle will not crank, you may need to replace the handle.
Lubricate the Handle
I am trying to crank the handle; however, the handle will barely move.
Dirt or Grease Build Up'
You may need to clean dirt, debris, or old grease out of the handle.
Replace or Lubricate the Gears
The gears will not turn smoothly, so they appear to be rough when I am turning the handle.
Spool Issues
Line Will Not Cast
I cast my line, but it stops and drops after only about 10 feet, even though I have enough line for around 70 feet. Most rods hold in excess of 100 yards of line.
Line Jamming
Your line may jam above the spool line around the tensioners and become wrapped and tangled. You will have to remove the top cover to untangle the line.
Spool Line Properly
If the fishing line is old, brittle, stiff, or kinky, you need new line.
Damaged Back Cover
The Outer Back Cover Is Cracked and Needs To Be Replaced
I want to use my reel, but there is a grinding sound when I turn the handle.
Replace Damaged Back Cover
Your cover has been damaged in some way which can lead to moisture, dirt, and grime entering the back cover of the reel, and that may lead to rust. You will need to replace the back cover.
Stuck Thumb Button
Thumb Button Will Not Release
After I cast the reel, the thumb button will not pop back up after reel has been engaged.
Thumb Button Hinge Ears are Broken
Your hinge ears might be broken. Replace the thumb button or back cover assembly. These parts can be ordered online.
Thumb Button Spring is Broken or Bent
Your thumb button has been hanging up because of the hinge ear. You will need to pop the back cover off and bend the spring back to the original position.
Lesley Drummond
crwdns2935283:002/02/16crwdne2935283:0
16 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
South Arkansas Community College, Team 1-1, Mitchell Spring 2016 crwdns2935289:0South Arkansas Community College, Team 1-1, Mitchell Spring 2016crwdne2935289:0
SACC-MITCHELL-S16S1G1
crwdns2944067:017crwdne2944067:0
My drag will not loosen up .you can adjust the knob but it does not loosen up.
stevie rudolph - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have this same problem. Let me know what you find out.
Terrence
Terrence Choates - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I was fishing one time, my rod fell in the sand and sand got inside the reel. This caused the same problem until I reeled in the line while putting it under a load on a lower drag setting, which loosened the mechanism inside.
Audiovox - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
zebco 33 rhino max. When my boy uses the rod he sometimes holds it upside down with the reel on bottom, and then reels backwards. Is there a way to make the reel stop doing this since my 5 year old will not stop stop reeling in reverse.
Johnwest2u - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’m looking to reassemble a 33 max. I have no manual. Any idea where to find a schematic?
Dwayne Goods - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 62
crwdns2959996:0crwdne2959996:0 24,257
