crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
A Body Part is Broken
Drone has a broken body part that hinders its ability to work properly.
Broken Propeller Arm
If a propeller arm is broken, try replacing it with the arm replacement guide.
Broken Propeller
If a propeller is broken, it can be easily replaced with the propeller replacement guide.
Broken Landing Gear
If the landing gear is not working properly, refer to the landing gear replacement guide.
Broken Camera
If the camera is broken, refer to the C23 camera replacement guide.
Broken Motor
If the motor has quit working, refer to the motor replacement guide.
The Drone is not Responding to the ST16S Ground Station
The drone does nothing when the ground station tells it to move. Drone and ground station appear to not be connected.
The ST16S Ground Station or the Drone Was not Powered On Correctly
In a case where the drone is on and the remote is on and they are not connected try to do these simple steps first. Turn off both the ground station and the drone. Once completely powered off, turn both the ground station and drone back on and check for a connection between the two.
The Ground Station and Drone are not Bound
Binding is usually done at the factory but in case your drone and ground station become unbinded here are the steps to binding.
Step 1: Turn on the Typhoon H Plus and let it initialize. You will know initialization is complete when the two LED’s on the rear arms blink blue.
Step 2: Flip over the Typhoon H Plus until all LED lights quickly blink yellow. Once the lights are blinking yellow flip the Typhoon H Plus back onto its legs on level ground.
Step 3: Turn on the ST16S ground station and wait a few seconds for the camera to align itself and all systems to connect.
Step 4: On the ST16S ground station tap the settings icon in the top right corner. Then select the network icon that looks like a bar graph that rises to the right. After you select the network icon select Drone.
Step 5: Press the refresh icon then press OK to unbind the RC link. Select the receiver that corresponds with your drone listed in the column and wait until a tip pops up letting you know the binding is completed.
The C23 Camera is not Streaming
The photos and videos are not showing up on the ST16S ground station.
ST16S Ground Station did not Power On Correctly
Try turning the ground station completely off and powering the ground station back on.
C23 Camera and ST16S Ground Station are not Binded
Binding the camera and the ground station can be completed by following these steps:
Step 1: Switch on the ST16S ground station on first then turn on the Typhoon H Plus.
Step 2: Select the settings icon in the top right corner followed by the network icon that looks like a bar graph that rises to the right.
Step 3: Type of serial number of the C23 Camera in the window. The serial number is on the side of the camera.
Step 4: Type the password “1234567890” into the pop up window to authorize the camera and then select OK to confirm.
If the camera does not connect within a reasonable amount of time close the pop up window and repeat the steps again.
The Battery is not Charging
The battery is not producing power or the battery life is short.
Battery LEDs Flashing Red and Green
Charger is balancing the cells to charge evenly. This is normal. The charger will flash green when balancing and charging are complete.
Swollen Battery Pack
Do not attempt further use, as you may risk damage to the drone. Discard the battery immediately and install a new one.
Uncycled Battery
Charge fully, then use until 30% battery life. Cycling the battery a few times in this way calibrates it and improves battery life.
Heavy Battery Usage
Using the drone until the battery dies degrades battery life. To prevent battery degradation, begin recharging your the drone at approximately 30% battery life.
Battery Cell Shows Significantly Lower Voltage than Others
The battery cell may be too out of balance for the charger. This cell must be charged individually with a universal charger to bring it in line with the other cells.
The Pictures and Videos are Unclear
The camera is not producing a clear image.
Blurry Pictures in Video Mode
Photos taken in video mode load pictures as low quality JPEGs. Set to picture mode when taking pictures. You can set your camera to picture mode by:
Step 1: Tap on “camera” at the bottom right of the ground station display.
Step 2: On the right of the screen, two small icons will appear. Press on the camera icon located under the video icon.
Not Optimal Camera Settings
Camera settings are not preset for best quality. To customize your camera settings:
Step 2: Press on the cog at the bottom right of the screen next to “camera”.
Step 3: Select Photo Mode and select dng.
Step 4: Tap on Image Style located under Photo Mode. Select gorgeous.
Camera Requires Calibration
Adjust the white balance to your preference. On the left of the display, there is a column of options for white balance. Select the optimal one (Cloudy, Sunny, Fluorescent, etc…) based on your current environment.
Video and Picture Background Blurry
Higher values of ISO function better when there is less sunlight while lower values of ISO function better with more sunlight. To adjust ISO:
Step 1: On the left of the display, tap on the black and white circle containing a plus and minus sign and is labeled Auto.
Step 2: Select the large red Auto icon at the top left.
Step 3: Press on the large red M icon.
Step 4: Set ISO to 100 or adjust as necessary.
Blurry Camera in Certain Areas
The camera may be defective and needs to be sent back to the manufacturer for inspection.
Dirty Camera Lens
Use a microfiber cloth to brush away any dirt, dust, or grime.
Brice Black
crwdns2935283:001/23/20crwdne2935283:0
557 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G1, White Winter 2020 crwdns2935289:0Cal Poly, Team S2-G1, White Winter 2020crwdne2935289:0
CPSU-WHITE-W20S2G1
crwdns2944067:010crwdne2944067:0
How about a Typhoon H plus when you push the red button to start up the motors for flight and then all the light on the drone flash red and gives off three or so beeps. Can not fly at all. Even if you push the take off icon and select start the props spin up and then with in a few seconds it shuts down.
Bret Newman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi
John J Cavanaugh here writing
I havent used my hplus for awhile especially during the winter months
here in New England. I'm in Massachusetts… USA
I've tried to charge the batteries and all that's happening is a blue error light everytime i try to charge each of my three fully discharged batteries… I've tried to find utube videos and have looked for other resources to resolve this issue…
The batteries too ; are slightly puffy/ puffed out as well. Not sure if that's apart of my problem here…
Please help
I thank you
John C
John J Cavanaugh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Mt typhoon loon is blanking purple
Melissa Coin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Re: The advice above about trying to resolve the Typhoon H not responding to the ST16 controller. "The Ground Station and Drone are not bound". It says to turn on the drone on first (Steps 1 and 2), then the Ground Controller (Steps 3 onward). My manual says to NEVER switch on the drone before the ground controller. On the Yuneec Pilots forum, owners have reported bricked equipment after doing this. What is the truth???
martin.redman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,996
