The Basics
  • Check Power Source: Ensure your console's power cable is functioning correctly, it is plugged in, and the outlet it is plugged into is powered on.
  • Check the connection to your Display: If the console's front power indication LED is on, the issue could be that your console is not seeing your display.
    1. Check your HDMI cable. Ensure that the cable is securely connected to the display and console.
    2. Plug the HDMI into a different port on the TV if you have one available, or try using a different HDMI-enabled device.
    3. Try to use a new HDMI cord.
  • Perform a Hard Reboot: Hard rebooting your console will resolve any significant software issues that could prevent your system from rebooting normally.
    • For the Xbox 360 consoles, you'll need to turn the console off and then hold the Bind button (the small button next to the front USB flap) while you turn on the console on the console's power button.
    • For the Xbox One from now on, hold the power button on the front of the console for 10 seconds, releasing it only after the device shuts down.
  • Ensure your external PSU isn't overheated: If your system has an external power supply, check if the LED on the PSU is red. If it is red, you will need to allow it to cool down and ensure that the PSU's fan is cooling the unit.
Power Surge
Solution: Reset your power supply
If you recently experienced a power surge, your power supply's protective mechanisms may have been tripped. Resetting the power supply is a relatively easy fix.
  • Resetting an External Power Supply: All Xbox 360 and the original Xbox One consoles feature an external power supply, which can be reset with the following steps.
    • Unplug the power cables from the console, electrical outlet in the wall, and power supply.
    • Wait 10 seconds.
    • Firmly plug the power cable back into the electrical outlet and the power supply. Do not plug the power unit into the console yet.
    • Check the color of the LED on the Power Supply. The Xbox 360 and the Xbox One will have different LED color codes.
  • Resetting an Internal Power Supply: The Xbox Series X|S, Xbox One X, and Xbox One S consoles feature an internal power supply, which can be reset with the following steps.
    • Unplug the power cord from the console.
    • Wait 10 seconds.
    • Plug the cord back into the console and press the Xbox button on the front of it.
Faulty Power Supply
Solution: Repair or Replace the Power Supply
In some cases, Power supplies can be damaged by overheating or a significant power surge. Power surges can cause capacitors inside your power supply to burst, preventing your system from booting properly.
  • Check the Fan in your Power Supply: Some PSUs, specifically the Xbox 360 and Xbox One Consoles, have a cooling fan to prevent the Power Supply from overheating. Check to see if the fan is spinning when powered on, and if you are comfortable with it, replace it if it is not functioning properly.
  • Replace the Power Supply: If your PSU is faulty, you must replace it with a new one. iFixit also features guides for replacing the PSU for several different Xbox consoles.
Faulty Motherboard
Solution: Replace the Motherboard
What if your Xbox still does not power up, even after following all the troubleshooting steps above? Signs point toward a problem with the motherboard or surrounding components.
Solution: Replace the Motherboard and the Disk Drive
  • Perform a thorough visual inspection of the circuit boards for any signs of burns or damaged components. Suppose you observe any visible damage, such as burns or parts that appear to be physically damaged. In that case, you may need to replace the motherboard.
About the Author
Jake Mehnert
With a passion for tech repair and over six years of hands-on experience, I’ve worked extensively on laptops, from MacBooks to Acer Chromebooks, while diving into game console hardware repairs for Xbox, PlayStation, and Nintendo Switch controllers. My career began with maintaining Point of Sale systems in a major theme park, where I developed a keen eye for diagnosing hardware issues. Now, I apply my skills in an educational setting, tackling everything from computer repairs for students and teachers to network troubleshooting. I hold Network Administration, Cybersecurity certifications, and more, backed by a Bachelor's in Computer Science.
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
50.323 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:070crwdne2931471:0
crwdns2935297:01.152crwdne2935297:0
Hoi Goedemiddag
Ik heb en xbox s en wite en het is moelk uit te leggen maar ik heb. Hem nu aan staan maar het zouw zijn dat tie zo weer uit val want hij wil het niet meer doen en ik dnek door stof maar ik weet het niet zo goed
Jordy Vansumren - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 223
crwdns2959996:0crwdne2959996:0 2,295
