Xbox One will not turn on
The front status light stays dark, and/or the Xbox One will not power up.
Device not plugged in
Check to make sure that the power supply is plugged into a power outlet and that the other end is properly plugged into the Xbox One.
Bad power outlet
If your device is still not turning on, try plugging directly into a different power outlet, not through a surge protector.
Bad power supply
If the power outlet is providing power, but the console still does not turn on then the power supply may be the issue. Check the light on the power supply; if the light is solid white or orange then the power supply is working properly. If there is no light, unplug the supply and let it cool for 20 minutes, then try plugging it back in. If it still does not light up then you need to replace the power supply.
Bad motherboard
If the power supply light is on but your device still does not turn on, then the motherboard may be the problem. If it is, you may need to replace the motherboard.
Other problems
If you’re still having trouble, visit the Xbox One Won’t Turn On wiki for more information.
Disk drive not accepting disk
The drive is making a clicking or grinding noise or not taking the disk.
Bad disc drive
If the disc drive is clicking or making grinding noises then it is bad and should be replaced.
Television screen not displaying anything
Xbox One is on but the television screen is still blank, static, or blue.
HDMI cord in wrong port
If your television and Xbox are plugged in properly and turned on but your television does not display anything, the HDMI cable could be plugged into the wrong port. Check to make sure that the cable is plugged into the "HDMI OUT TO TV" port on the back of the console. Also make sure that the cable is plugged into the correct input port on the television.
Bad HDMI cable
If the HDMI cable is plugged into the correct port but the television still does not display, the HDMI cable may be the problem and you should replace the cable.
Incorrect Xbox One settings
If the cable works but the television does not display then the Xbox One may be configured incorrectly. You need to reset your display settings:
1. If there is a disc in the drive, eject it.
2. Press and hold the Xbox button for five seconds to turn off the console.
3. Press and hold both the Xbox button and the eject button until you hear a beep from the console.
Note: This will make the Xbox display in the lowest resolution. If you wish to change the resolution, follow the steps under the "TV not at best resolution" troubleshooting option.
TV issues
If the Xbox still does not connect to the television then the TV may be the problem.
Xbox One not connecting to the internet
Xbox One says that it can't connect or continually loses connection.
Router Malfunctioning
If the console does not connect to the internet then your router may be the problem. Follow the factory directions to reset or power cycle your router. A general method of resetting a router is to:
1. Shut down your devices.
2. Turn off the modem, then the router and unplug the power cables.
3. Wait for 30 seconds.
4. Plug the power cords back in but do not turn them on.
5. Turn on your modem and wait for the lights to stabilize.
6. Switch on the router and wait for the lights to stabilize.
7. Turn your devices back on and check for internet connection.
Reconnect at a different time
If your device still does not connect after power-cycling the router, try reconnecting to the internet in 1-2 hours.
Hard reset
If the Xbox still does not connect to the internet, you should do a hard reset:
1. While the Xbox is on, press and hold the power button for five seconds and the console will power down.
2. Wait 30 seconds then press the power button to turn the device back on.
3. Try to reconnect to the internet.
Bad Wifi board
If the Xbox still does not connect to the internet, you may have a bad wifi board and you may need to replace the Wi-Fi board.
Television isn't displaying in 720p or says that the settings are incorrect.
Incorrect settings
If your TV is displaying the Xbox screen, but not at the best resolution, then your Xbox may be configured to the incorrect settings. To fix this you need to adjust your display settings:
1. Press the Xbox button on the controller to reach the Home screen.
2. Press the Menu button and select the Settings option.
3. In the Console settings column, select Display & sound.
4. Choose the appropriate display and picture settings for your TV.
Console turning off unexpectedly
Console powers down in the middle of a game or shortly after turning on.
Incorrect settings
If your Xbox turns off unexpectedly after a period of inactivity you may need to adjust the settings so that it does not turn off automatically:
1. Turn the console on and press the Xbox button on the controller to reach the Home screen.
2. Select the Settings option.
3. Select Power & startup then Turn off after.
4. Select your preferred period of inactivity before the console automatically powers down.
Bad ventilation
If your Xbox still turns off unexpectedly then it may be improperly ventilated. If you receive a message saying that the console is getting improper ventilation then you should:
1. Turn off the console.
2. Wait at least an hour.
3. Move the console to a well-ventilated location.
4. Restart the console.
A well-ventilated location is one where there are no objects on, under or right next to the console. Ensure that all of the vents are clear and have good air flow.
Bad power outlet
If your console turns off unexpectedly during use or inactivity, the power outlet may be bad or the power cord could be plugged in incorrectly. Try plugging the supply directly into a different outlet, not through a surge protector and check that the cord is properly plugged into the outlet and the console.
Bad power supply
If the power outlet works but the console still turns off, the power supply may be the problem. Check the light on the power supply; if the light is solid white or orange then the power supply is working properly. If there is no light, unplug the supply and let it cool for 20 minutes, then try plugging it back in. If it still does not light up then you need to replace the power supply.
Other problems
For further information and possible solutions, see the Xbox One Turns Itself Off wiki.
Disc drive not ejecting
Disk will not come out of the disk drive or is stuck partway out.
Manually eject disc
If your Xbox One will not eject the disc in the drive then you can manually eject it using a standard paper clip:
1. Power down the console and disconnect the power cord and any other cables connected to it.
2. Uncoil the paper clip.
3. Locate the yellow sticker behind the vents on the left side of the console. The sticker is close to the front of the Xbox near the disc drive.
4. Locate the eject hole next to the yellow sticker and insert the paper clip into it.
5. The disc should pop out of the drive slightly and you can pull it out the rest of the way with your hand.
Make sure that the disc isn't dirty or sticky and does not have a label that will prevent it from ejecting from the console again in the future.
Bad disc drive
If the console frequently does not eject discs properly and you have checked that the discs are clean and should eject properly, then there may be an issue with your disc drive and you can replace the disc drive.
Wireless controller not connecting or not maintaining connection
Console says your controller is not connected or is not responding to controller commands.
Bad controller batteries
If your controller does not connect to your console or it frequently loses connection then you may need to replace the batteries in your controller or recharge the battery pack.
Note:
1. If the batteries in the controller are low then you may have only partial functionality, such as the vibration not working. This is a function of the controller to extend battery life and full functionality will return when the batteries are replaced or the battery pack is recharged.
2. If the batteries are low then the controller may have enough power to turn back on for a short period of time, but it will not stay on for long until the batteries are replaced or recharged.
3. Your wireless controller will function as a wired controller when it is plugged into the console with a USB-to-micro-USB cable. It can also be used in this capacity without batteries or a battery pack in the controller.
Controller out of range
Xbox One controllers are designed to operate within 30 feet (9.1 meters) of the console. Be sure that you are within this range while trying to use your controller or the controller may lose connection.
Note: Other factors such as walls or wireless interference may also affect this range.
Wireless interference
Check to see if there is another wireless device nearby such as a cordless phone or wireless router, or if there are metallic objects such as shelves in between the console and the controller. These objects may cause interference with the controller's wireless connection to the console.
Too many controllers are connected to the console
If there are already eight controllers connected to the Xbox One then you will not be able to connect an additional controller.
Hard reset
If the controller still does not connect to the Xbox One then you should do a hard reset:
3. Check to see if the controller connects to the console.
Reconnect the controller
If the controller still does not connect then you can try to connect it to the console again:
1. Turn on both the Xbox One and the wireless controller.
2. Hold down the wireless connect button on the top of the controller until the Xbox button flashes.
3. Release the button then hold it down again. The light on the controller should stay on, indicating a connection to the console.
Bad controller
If a specific controller still does not connect, but others successfully connect to the console, then you may need to replace your controller.
Bad Wifi board
If you cannot connect any controllers to your Xbox One then the Xbox hardware may be the issue and you can replace the Wifi board.
Fan not working
Fan is completely silent or making a harsh grinding noise.
Bad fan
If the fan does not run when the Xbox One is turned on then it is defective and should be replaced.
5 SolutionsXbox One Will Not Turn On
The front status light stays dark and/or the Xbox One does not power up.
Potential causes include device not plugged in, bad power outlet, bad power supply, bad motherboard, or other problems.
View all causes and solutions.
1 SolutionXbox One Disk Drive Not Accepting Disk
The drive makes a clicking or grinding noise or does not accept the disk.
Potential cause includes a bad disc drive.
4 SolutionsXbox One Black Screen
The Xbox One is on but the television screen remains blank, static, or blue.
Potential causes include HDMI cord in wrong port, bad HDMI cable, incorrect Xbox One settings, or TV issues.
4 SolutionsXbox One Not Connecting to the Internet
The Xbox One states that it can't connect or continually loses connection.
Potential causes include router malfunctioning, reconnecting at a different time, hard reset, or bad WiFi board.
2 SolutionsTV Not at Best Resolution
The television does not display in 720p or indicates that the settings are incorrect.
Potential causes include wrong console settings or TV settings issue.
2 SolutionsKinect Not Pairing With Console
The Kinect is not recognized by the Xbox One.
Potential causes include bad Kinect cable or bad Kinect sensor.
2 SolutionsXbox One Making a Grinding Noise
The Xbox One produces a loud grinding or clicking noise.
Potential causes include the fan or hard drive.
3 SolutionsXbox One Disc Stuck in Disc Drive
The Xbox One console will not eject the disc in the drive.
Potential causes include a hardware malfunction, and a faulty disc drive.
5 SolutionsController Not Connecting
The controller does not connect or frequently loses connection.
Potential causes include low battery, too many controllers connected, interference, bad controller, or bad console.
Gwendolyn Church
crwdns2935283:001/27/14crwdne2935283:0
1,503 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-22, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 6-22, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S6G22
crwdns2944067:061crwdne2944067:0
You are a genius! Thank you I have been pulling my hair out trying to get my xbox one working upstairs to use on spare tv temp.TYSM.
nikkiskae75 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
No picture of Xbox on TV. Have tried everything, even the 'eject' thing. Still no picture. Turned it on and off, still no picture. Xbox appears to be on with usual white ball light on front. Please help
Paul Lewis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 85
crwdns2936753:030crwdne2936753:0 287
crwdns2959996:0crwdne2959996:0 261,359
