crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Buttons Get Stuck
When the controller's buttons are pressed, they remain in the down position after the user has lifted his or her finger off the button.
Residue Is Under the Buttons
The buttons might have residue underneath or around the buttons because of continued use or spills. The buttons can be cleaned using rubbing alcohol and cotton swabs. Follow the Disassembly Guide to make the buttons more accessible. Then, dip a cotton swab in rubbing alcohol and clean each button area thoroughly. If the buttons are still not functioning properly, they can be replaced using the Buttons Replacement Guide.
Parts: Button Covers, Button Gasket
Tools: iFixit Opening Tools, T6 Torx Screwdriver, T9 Torx Screwdriver, Soldering Station, Alcohol Dispensing Bottle, Cotton Swabs
The Button Assembly Spring Is Broken
The button assembly requires a spring to bounce back into position. Heavy use associated with the Xbox One Elite (Wireless) Controller may cause the internal assembly to break or malfunction. If the buttons do not spring back after being pressed, then the spring may be damaged. For damaged springs, refer to our Buttons Replacement Guide.
Parts: Button Assembly
The Controller Doesn't Vibrate
During gameplay, the controller doesn't vibrate when it's supposed to.
The Batteries Are Low
If the controller's batteries are low, then it might not vibrate. Try replacing the batteries using the Battery Replacement Guide.
Vibration Feedback Isn't Supported
The controller might not vibrate if a game doesn't support vibration feedback. Check the game's manual or settings to see if it offers vibration feedback.
The Vibration Setting Is Disabled
The controller might not vibrate because the game's vibration setting is disabled. Check the game's settings to make sure that vibration feedback is turned on. To locate the game's settings, check the game's paper manual for directions.
The Rumble Motors Are Disconnected
If the controller does not vibrate, he wires that connect the rumble motors to the controller's main motherboard might have been disconnected. Head to the Rumble Motors Replacement Guide to see how to reconnect the wires back to the motherboard board.
The Rumble Motors Are Defective
If none of the previous options have worked, then the controller's rumble motors might be broken or defective. In this case, check out the Rumble Motors Replacement Guide to replace the defective motor(s).
The Back Triggers Don't Work
When the controller's left or right trigger is pressed, it no longer produces the expected action during gameplay.
Dirt Is Under the Trigger
If the trigger does not function properly, there may be dirt under the trigger preventing communication between the trigger and the rest of the controller. Using the Trigger Disassembly Guide, remove the back of the controller to make the malfunctioning trigger more accessible. Then, dip a cotton swab in rubbing alcohol and clean each trigger area thoroughly.
The Trigger Assembly Is Defective
If cleaning the trigger does not solve the problem, the trigger assembly may be damaged or broken. To replace the broken trigger assembly, refer to the Trigger Assembly Replacement Guide.
The Screen's Objects Move Without Controller Use
Unintentional movement occurs during gameplay without the user touching the thumbsticks.
Dirt Is Under the Thumbsticks
Dirt or other contaminants may be preventing the thumbsticks from functioning properly. To clean the thumbsticks, first remove them from the controller using the Thumbsticks Replacement Guide. Then, get a can of compressed air and try to blow the sticks out. If this does not work, use a cotton swab dipped in rubbing alcohol to clean residue off the electronic unit underneath the thumbsticks.
The Thumbstick Is Broken
Due to heavy use, the thumbsticks or the motherboard below it might be broken. Use the Thumbsticks Replacement Guide to replace the thumbsticks.
The Controller Will Not Turn On
The controller does not turn on when fully charged.
The Controller Was Disconnected During a Firmware Update
If your controller was disconnected during a firmware upgrade, it will not function until the firmware is recovered. To do this, the controller will need to be updated from scratch. Note: In this condition, the wireless on the controller is nonfunctional. This must be done over USB.
Tip: If you have problems getting the controller to turn on, removing the batteries for 15 minutes before recovery can resolve this issue.
Plug your controller into an Xbox One console or a PC. At this point, the method will vary. It should also be noted one functional controller is required to use a console for controller firmware recovery.
To recover the controller on a console, follow these steps:
  • Step 1: On the console, navigate to Devices and Accessories.
  • Step 2: Find the Elite controller. It should say Update Required if it is the correct controller.
  • Step 3: Recover the controller firmware.
PC recovery requires Windows 10 as a prerequisite - Windows 7/8.x DO NOT WORK. Newer versions of Windows 10 do not require a Microsoft Account for the download, but older versions usually do. Users on older versions of Windows 10 may need to convert one of the accounts on the computer to a Microsoft Account, or log into the Store without altering the account.
  • Step 1: Install the Xbox Accessories application.
  • Step 2: Once Xbox Accessories is installed, plug the controller in. It should turn on and say Update Required if your controller is visible to the PC and Xbox Accessories.
  • Step 3: Click Update Required and allow the firmware to reinstall.
If you followed these steps correctly, your controller should be functional again.
The Controller Does Not Function on the Computer
When the controller is plugged into the computer using a USB cord, the controller does not function.
The Controller Drivers Are Not Installed
In Windows 7 and 8.x, the Xbox One Elite controller is known to have problems with automatic driver installation. This issue is well documented and caused by a lack of drivers bundled with the operating system and Windows Update detection problems. Unlike the standard controller, the only option to fix this issue is manually installing the driver through Device Manger.
Note: The Elite controller does not offer a .exe driver package. The driver must be obtained through Microsoft Update Catalog. This also means administrative permissions (or the Administrator password) is required to fix the controller when automatic driver detection fails if you have a Standard or Limited account.
  • Step 1: Plug in the controller. The initial driver installation is very likely to fail, so be prepared to exit the window. If it works the first time, then the driver was already on the system.
  • Step 2: Open Device Manager and select the Xbox One Controller. This is typically located under Xbox Peripherals (Legacy).
  • Step 3: Select the Driver tab.
  • Step 4: Click Update Driver.
  • Step 5: Use Search Automatically for Updated Driver Software. Skip this step if you want to retain a local copy on your device because your controller is used on multiple PC's.
  • Step 6: If Step 5 did not work, download the driver from Microsoft and put this somewhere on your computer for manual installation.
Greg Chu
crwdns2935283:009/18/17crwdne2935283:0
726 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team S18-G4, Forte Fall 2017 crwdns2935289:0Cal Poly, Team S18-G4, Forte Fall 2017crwdne2935289:0
CPSU-FORTE-F17S18G4
crwdns2944067:021crwdne2944067:0
hello, my control restarts in xbox and windows 10 and does not allow me to update firmware any other option?
Arturo J - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have a wireless controller and let say my barries dead and I grab a wire for my controller and I plug it in the controller does turn and on my sceern say please reconnect your controller and I don’t know if it the wire or the controller
Matthew Wolski - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So my elite controller rb button acts like it is always down but it is up.
Colin mclaighlin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My controller turned off while I was playing a few days ago and wouldn't turn back on I let it sit for like 2 hours and came back and it turned on. Was playing today and in the middle of a match it disconnect and now it won't turn back on. I've tried new batteries, USB , hard resetting console. Any ideas?
Dark Sphere 99 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My elite cotroller disconected while update. My xbox and pc can't see my elite controller even if it's wired. I can't use it now in any way. How can I fix this? I tried everything. I just have to controller for a month now.
Koos Luijk - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 179
crwdns2959996:0crwdne2959996:0 73,515
