crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Low Batteries
Your batteries may be low. If the batteries are low, the controller's wireless signal strength may be weak and therefore will not connect to the console. You are going to want to replace your batteries or charge the controller.
Parts: AA Batteries for Xbox One, Xbox One Controller Charging Cable
Tools required: None
Another Wireless Device Is Interfering
A conflicting signal may be responsible for connectivity issues. Consider turning off nearby wireless devices and reconnecting the controller.
Too Many Controllers Are Connected
Make sure you do not have more than eight controllers connected. That is the limit for the Xbox One console.
Controller Inactivity
If you set down your controller for longer than fifteen minutes and then come back to an unresponsive controller, you may need to turn the controller back on.
Controller Is Out Of Range
Your Xbox One Controller signal has a range of 30 feet (9.1 meters). Make sure you are within this range.
Controller Is Not Synced
If you sync your controller to another device, you will need to re-sync it back to your console. To do this, turn on the Xbox One and hold down the sync button on your controller. Simultaneously, hold down the sync button on your console until the light on your controller begins to flash at a rapid pace. Once this happens, release both sync buttons. Your controller should now be connected after about five to ten seconds.
Mic Preventing Connection
Some people have reported that the controller will not connect with the headset mic plugged in. Unplug the mic, and reconnect. Sync if necessary. Plug the mic back in after establishing a connection.
If you are using a Model 1697 controller, your internal headphone jack may be damaged. Try unplugging the mic and trying again. If you continue to have problems, try a different pair of headphones that are known to work.
Parts: Xbox One headphone jack, Xbox One headset adapter
Tools required: T6 Torx, TR8 Torx, Spudger, tweezers (recommended)
Tools are not required if you use the Xbox One headset adapter to fix the issue.
Battery Degradation
If you've been using your controller for long enough, you'll know that the battery life isn't what it used to be. If your controller has been dying quicker and quicker up to this point, or if you've left your controller uncharged for multiple months, the battery is likely degraded to the point that it can no longer supply sufficient power to the controller. You'll need to open up the back of the controller and replace the battery pack, which can be done using this guide.
Garrett George
crwdns2935283:001/22/15crwdne2935283:0
6 482 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-15, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 20-15, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S20G15
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 2,005
