crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The controller is not powering on
The controller does not turn on when pressing the Xbox, big-”X”, home button.
Batteries are dead
If the controller is not turning on - no buttons are lighting up and Xbox is not recognizing controller connection - make sure the batteries are fully charged. To do this, you will need 2 AA batteries.
  • Tip: *** Make sure the batteries are placed properly in the controller in that the “+” side of the battery matches with the “+” labeled side on the controller and the “-” side of the battery matches with “-” side on the controller.
Follow these steps to check/change batteries:
Step 1: Turn controller on its backside.
Step 2: Push small release button. It will look like a standard eject button with a line and down arrow underneath. The cover of the battery compartment will eject.
Step 3: Make sure the battery’s “+” and “-” sides match with the controller’s marked “+” and “-” pictures. If the controller still won't turn on, move to step 4.
Step 4: Take 2 new AA batteries and place them in with the corresponding “+” and “-” signs on the controller.
Parts Required: Two AA batteries
Buttons or triggers are stuck
Buttons not immediately returning to resting position after being pressed
Built-up dirt or sticky residue
Dirt can accumulate from everyday use and soda spills can cause a sticky mess! See our guide for Button Replacement to remove the controller casing and access the buttons for cleaning. Once the buttons are exposed, dip a clean cotton swab into rubbing alcohol and carefully clean around the button. Leave the cover off until the alcohol has completely dried, then place the cover again.
Tools Required: T9 Torx
Crumbs stuck under buttons
If you can see the food pieces lodged between the buttons, try to use tweezers to pull the piece out. If tweezers are too large, try a fine-tipped brush (like a paint brush) or a can of pressurized air to remove the food. If you still can’t get the crumbs out, see our guide for Button Replacement to remove the controller casing and access the buttons. Once the buttons are exposed, use a fine-tipped brush or a can of pressurized air to remove the crumbs. After the food has been cleaned out, place the cover again.
Tools Required: T9 Torx, Brush, Pressurized Air
Buttons' springs are broken
If you’ve dropped the controller, threw it at a wall in a post-loss rage, or have been doing some hardcore gaming, the buttons may break. See our guide for Button Replacement to repair the buttons.
Parts: Button Covers, D-Pad Cover, Analogue Triggers
Controller isn't connected to console
The console does not recognize the controller and the controller won’t connect.
Controller isn't synced to console
To sync controller to console, turn the console on. Turn on controller and press and hold the big home “X” button until the wheel lights begin to flash. On the console, press and release the connect button - this button will look like three, thin arrows pointing left. Within 20 seconds, press and release the connect button on the controller - this button will look exactly like the connect button on the console. The light on the controller’s right handle will flash while it connects to the console. Once the controller is connected to the console, the center ring around the big home “X” button will light up and stay on.
Batteries are dead
If the batteries are low on juice, this can affect the signal strength between the controller and console. Try changing the batteries in your controller and see if you get connection after powering the controller back on.
Parts Required: 2 AA batteries
Console needs to be reset
Sometimes if you reset the console, the controller might connect on the second try. Go ahead and power off the console, wait 30 seconds, and turn the console back on. Turn on the controller and try syncing again.
Another wireless device is interfering
Connectivity issues can be related to a conflicting signal. Consider turning off unused, nearby devices and reconnecting the controller.
Too many controllers are connected
The Xbox 360 only allows 8 controllers to be connected at one time. If more than 8 controllers are connected, disconnect the controllers. To disconnect a wireless controller, press and hold the big home “X” button for 3 seconds and then select “turn off controller”.
Controller won’t vibrate
When playing a game, the controller won’t vibrate.
Vibration settings are not enabled
There is no universal setting for vibration controls under Xbox 360 settings, however, most games that use vibration will have vibration settings you can navigate to and adjust the vibration there.
Game doesn’t support vibration
First try using a different controller and see if vibration occurs. If it does not occur, then you can conclude that the game does not support vibration.
Batteries are dead
Sometimes low battery life will not support vibration. Try putting new batteries in the controller and see if vibration occurs. Also, you can check battery life by clicking the big home “X” button and navigating to controller settings. The battery life will show for the controller’s batteries.
Vibration motor is defective
If you have tried all of the above and the controller still won’t vibrate, then the controller has a defective vibration sensor. See ‘Vibration Motor Repair Guide’ to fix the vibration motor in the controller.
Experiencing input lag
You are experiencing a delay between the console receiving a signal from the controller.
Controller sensitivity needs to be adjusted
Sometimes the controller will be too sensitive or not sensitive enough and this can interrupt the use of the controller. There is no universal sensitivity setting to adjust for this, however, most games will have an option to adjust the controller’s sensitivity under the games’ controller settings.
lauren paganella
crwdns2935283:002/15/18crwdne2935283:0
485 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S16-G5, Boczar Spring 2018 crwdns2935289:0USF Tampa, Team S16-G5, Boczar Spring 2018crwdne2935289:0
USFT-BOCZAR-S18S16G5
crwdns2935297:096crwdne2935297:0
crwdns2944067:06crwdne2944067:0
My xbox 360 steering wheel isnt turning on and it only works on batteries
Dawid Strazewski - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Xbox 360 steering wheel controller wheel is not turning, seems to have stuck towards left. The wheel manually turns, but the car just goes only towards left even though I turn the wheel to the right. Anyone has experienced this issue before. Thanks.
Bill - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The wheel does not turn on. The batteries are charged, and in the right polarity. What is this?
Wifi E - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
speed wheel wireless xbox controller doesnt want to start even though reciever is on.
James Johnson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My steering wheel is drive on the left but my won’t drive on the right Xbox 360
Jay'Den Robertson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 10,583
