crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device won't fully turn on
Reset your device to factory defaults. Take notice that this will revert your device back to when it was first made and shipped to a store. All your data installed after you got the device will be erased.
  1. Make sure the tablet is OFF
  2. Press and hold the Volume Up and Power buttons at the same time
  3. When the Android logo starts to flash, release the buttons
Note that this is general instructions for Android devices. If this does not work please check the manufacturers website on how to reset the device to factory defaults.
Error 101 when downloading Google Play Store apps
Most likely, you need to clear the cache for Google Play Services.
  1. Go to Menu, select Settings
  2. Select Application Manager, scroll down to Google Play Services
  3. Scroll down and select Clear Cache
Screen won't rotate
Your Auto Rotate screen lock is turned on.
  2. Select Display
  3. Check the box next to the Auto Rotate Screen
Cracked screen
Replace your screen.
  1. Gather appropriate tools (spudgers, plastic cards, suction cups, something to heat the glue up ex. hair dryer)
  2. Heat the edges of the screen evenly, and begin to pry the screen off with a spudger. As a section becomes loose, hold it in place with a plastic card.
  3. When the screen is nearly free of the adhesive holding it on, attach the suction cups to the screen and gently lift the screen away from the body of the tablet just enough to see under it.
  4. Make note of all attachments to the screen including the LCD cable. Other connections may include the WiFi antenna. Remove all attachments to the old screen.
  5. Remove protective film from the new screen and apply adhesive strips to the back.
  6. Attach any cables to the back and lightly press the new screen into place.
Adam
crwdns2935283:002/07/15crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Pasco Hernando, Team 5-4, Prince Winter 2015 crwdns2935289:0Pasco Hernando, Team 5-4, Prince Winter 2015crwdne2935289:0
PHSC-PRINCE-W15S5G4
crwdns2931471:06crwdne2931471:0
crwdns2944067:05crwdne2944067:0
i try to use app center and i get a “ unable to connect to server no peer certificate” message what can i do?
Javier Guadalupe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello I have had my tablet for going on 2 years now and I have not been able to use my device I try to go online an down load Google play because I have no other apps on it I'm able to get Gmail on it but that's it it's connected to WiFi but that still does not help with downloading.
Please explain in a easy way as to how to use my tablet please an thank you.
Victoria Vanderwal - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I've never had a password to unlock my tablet. When I turned it on a keypad popped up instead of opening as usual and I don't know how to get around the problem.
Chris Flaherty - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 8,689
