Miposaur will not turn on
Power switch is turned to the “On” position but lights do not turn on and Miposaur remains unresponsive.
Power switch may not be completely in the on position or may be broken
Check to see if switch is intact. Make sure it has a textured end that protrudes outside of the switch area enough that it can be easily moved from side to side. If the switch is broken try to move it to the on position, if it still does not turn on there may be internal damage or there may be an issue with the batteries, if so see the next section about low or dead batteries. If the switch is intact ensure that it is completely in the “On” position. It may be the case that the batteries are low or dead and in that case you should consult the next section.
Batteries may be low or dead
The batteries in your Miposaur may be dead or too low to power the toy. In this situation you should remove the batteries and replace them with new batteries. You can follow our battery replacement guide here.
Miposaur turns on but does not move
The Miposaur lights up and makes sounds but does not respond to commands.
Miposaur is on an unsuitable surface
Miposaur does not function well on slippery or very malleable surfaces, it must be placed on a carpeted or hard non-slippery surface.
The wheels are jammed or damaged
If the wheels are worn out, Miposaur may not go in the correct direction you want it to go. Try replacing the wheels. If you need help, refer to the replacement guide.
Objects can easily get stuck in between the wheels. Turn Miposaur over and inspect the wheels to make sure that nothing got caught in them.
Your hands are not close enough to Miposaur or you are moving them too quickly for the sensors to pick up on the signal
Make sure you move your hands slow and close enough to the sensor so that Miposaur can pick up on your movements.
Miposaur mobile app crashes or doesn’t work
You were using the Miposaur mobile app and it suddenly crashed.
You may have tried to access the “Settings” section of the app
Trying to access the “Settings” in the Android version currently automatically crashes the app. This should be fixed in an upcoming update but for now just don’t try to go to “Settings” or try using an iPhone or iPad.
You may have been using the “Follow” function in the app
The “Follow” function currently does not work in the Android app. This should be fixed in an upcoming update but for now just don’t try to use the “Follow” function.
Miposaur is not making noise
Miposaur responds and moves yet does not make sounds.
The speakers may be blown
The speakers may start to sound distorted after extended use of the Miposaur. The speakers may have blown out due to overuse. We recommend looking at the speaker replacement guide for directions on how to fix this issue.
There are loose wires in the speaker assembly
It is possible that the wires on Miposaur have become disconnected due to damage to the device or overuse. We recommend checking the speaker replacement guide to fix this issue.
The sound settings on the app are turned down
Open the app and access the "Settings" section. Increase the volume to the desired level. Note that currently this will not work in the Android version of the app.
The batteries are low
If the sound is coming out mumbled or quieter than usual, even on the higher sound setting when using the app, you may want to check the batteries as they may be dying. If the noise issue is due to low battery, consult the battery repair page here.
David Bedsole
crwdns2935283:012/04/17crwdne2935283:0
167 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
iFixit, Team S1-G1, Weber Summer 2018 crwdns2935289:0iFixit, Team S1-G1, Weber Summer 2018crwdne2935289:0
FIX-WEBER-SU18S1G1
crwdns2935297:0396crwdne2935297:0
crwdns2944067:08crwdne2944067:0
What if miposaur isn’t playing with his trackball
Erin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I found a glitch involving MiPosaur’s battery power. When the batteries get too low to get the device through a startup sequence, it may skip the sequence and continue to the “Low Energy“ sequence. Upon draining a small amount further, the toy plays a *squeak* sound repeatedly. However, the toy may not have enough power to play the sound and reboot upon playing it, which causes the sound to not be played, except with long-lasting batteries.
Michael Deitz - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Also, the MiPosaur was released in 2014, not 2015.
Using a CHiP SmartBall or SmartBand with a CHiP connected can confuse MiPosaur and activate a TrackBall mode.
My miposaur is acting crazy it is not listening to any of commands and is not following commands in miposaur app
yatin reddy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 3,793
