crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Sound Not Working
No matter what you do, this flashlight won’t make a sound.
Volume Selector Switch On/Off
Check to make sure your volume is turned on, if the switch is off, switch it to the low or high volume setting.
Speaker is Disconnected
If the flashlight fails to produce sound, the speaker may be disconnected. Use this guide to fix this.
Drained/Bad Batteries
If your flashlight is not making sound, you may need new batteries. Unscrew the battery cover and replace the two AAA batteries.
Light Not Turning On
The light isn’t working.
If the light is not turning on, you may need new batteries. Unscrew the battery cover and replace the two AAA batteries.
Light Bulb is Faulty or Disconnected
If the light bulb fails to produce light, you may need to reconnect the bulb or replace it. Use this guide to do this.
Ring Not Moving
The top won’t spin.
Spinning Mechanism is Broken
If the spinning mechanism is loose and won’t catch, the locking device may be broken. This guide explains how to disassemble and reassemble the outer spinning ring.
Locking Mechanism Won’t Release
If the spinning ring on the flashlight refuses to move, the locking mechanism may be jammed or broken. Consult this guide to fix this.
Ladybug Button Not Working/Stuck
The button’s mechanical components are broken.
If you press the button and nothing happens, you may need new batteries. Unscrew the battery cover and replace the two AAA batteries.
Button Won’t Move
Replace the button using this guide.
Speaker or Light May Be Broken
See our replacement guides for the speaker and light bulb if this is the problem.
Miscellaneous Issues
All previous solutions have been exhausted, what else is left?
Faulty Wire Connections
When your flashlight is not working, the wires originating at the motherboard may be disconnected or cut. Use this guide to replace the motherboard.
Corrosion on Motherboard
In the event that the device is not working, either water or battery acids have started to corrode the metal components of the motherboard, and may need to be replaced. Use this guide to do this.
Loose or Missing Components
Due to jarring or stress from impacts, some components may become loose or fall off completely, and then must be replaced.
Tess Puhak
crwdns2935283:008/27/15crwdne2935283:0
347 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-6, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 2-6, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S2G6
crwdns2935297:0108crwdne2935297:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 1,947
