crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the microphone audio appears to be muffled when your V-Moda Crossfade M-80 is in use, follow this page for possible solutions.
Damaged Hinges
The folding hinges on the V-Moda M-80s can cause noise or debris build up.
Solutions could be:
  • Tighten the screws in the hinge with a precision screwdriver to reduce movement and creaking.
  • Clean the hinge joints with a soft brush or compressed air to remove debris.
  • If irreversible damage persists, remove hinges and replaced with new ones.
Damaged Speaker Driver
Distorted, weak, or inconsistent audio with the Volta M 80s caused by internal speaker driver issues.
Solutions could be:
  • Lightly tap the air cup while audio is playing to check for loose driver components.
  • Adjust the cable connection to determine if sound cuts in or out from the driver.
  • Use compressed air to blow out any debris near the driver assembly.
  • Remove and replace speaker drivers if other methods prove unsuccessful.
Damaged Ear Pads
The audio may be affected if the ear pads limit the proper positioning
  • Readjust the v-Moda Crossfade M-80 on your head to see if it is not properly positioned.
  • Replace the ear pads to reduce the muffling sound.
Damaged Headband Cover
The headband cover is a STEEL-FLEX headband which can cause muffled audio if there is too much tension
  • Using both hands bend the headband slightly outward.
  • Bend headband until you find a balance between comfort and seal.
Hollis Wright
crwdns2935283:002/05/26crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 21-2, Samson Spring 2026 crwdns2935289:0Texas Tech, Team 21-2, Samson Spring 2026crwdne2935289:0
TTU-SAMSON-S26S21G2
crwdns2959996:0crwdne2959996:0 95
